DubNDodge Posted October 22, 2012 Report Share Posted October 22, 2012 Edit: Curses!! doubled posted. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
DubNDodge Posted October 22, 2012 Report Share Posted October 22, 2012 I figured I would ask my question in here rather than starting a new thread. What bit is used to cut holes for the subwoofer? Spiral Down Cutting? I understand you have to make several passes with a bit, but can the bit reach down if its a double baffle, 1.5"? Or do you do each board seperate then glue? Can a standerd non-plunge router work for cutting circles for subwoofer? I've found little deatailed information on cutting circles for subwoofers so far, or I'm just looking in the wrong spot Thanks '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
Torres Posted October 22, 2012 Report Share Posted October 22, 2012 i use this to cut my holes for woofers http://www.ptreeusa....sh_trim_300.jpg you use a flush trim but to cut circles? Link to comment Share on other sites More sharing options...
will77530 Posted October 22, 2012 Report Share Posted October 22, 2012 I figured I would ask my question in here rather than starting a new thread. What bit is used to cut holes for the subwoofer? Spiral Down Cutting? I understand you have to make several passes with a bit, but can the bit reach down if its a double baffle, 1.5"? Or do you do each board seperate then glue? Can a standerd non-plunge router work for cutting circles for subwoofer? I've found little deatailed information on cutting circles for subwoofers so far, or I'm just looking in the wrong spot Thanks i use the down spiral bit for 3/4 i do it in one pass any thing thicker i like to do multiple passes. i use a standard router for mine but a plounge router is easier Link to comment Share on other sites More sharing options...
HunterJohnson Posted October 22, 2012 Report Share Posted October 22, 2012 i use this to cut my holes for woofers http://www.ptreeusa....sh_trim_300.jpg you use a flush trim but to cut circles? Sorry it's like a flush trim with a triagle at the top to plunge into the wood Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
DubNDodge Posted October 22, 2012 Report Share Posted October 22, 2012 I figured I would ask my question in here rather than starting a new thread. What bit is used to cut holes for the subwoofer? Spiral Down Cutting? I understand you have to make several passes with a bit, but can the bit reach down if its a double baffle, 1.5"? Or do you do each board seperate then glue? Can a standerd non-plunge router work for cutting circles for subwoofer? I've found little deatailed information on cutting circles for subwoofers so far, or I'm just looking in the wrong spot Thanks i use the down spiral bit for 3/4 i do it in one pass any thing thicker i like to do multiple passes. i use a standard router for mine but a plounge router is easier So it is a spiral down bit then, cool. Are there different lengths of that bit or will all of them reach down 3/4"? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
kurupt305 Posted October 26, 2012 Report Share Posted October 26, 2012 whats a good size round over bit 3/4 or 1 inch Link to comment Share on other sites More sharing options...
