yungw33z Posted June 11, 2012 Report Posted June 11, 2012 i have 2 dual 2 ohm 12'' SA12's from day 1 of purchase i wired them at 2 ohms on my trx700d which will put out 530 rms. they didn't play so i figured it wasn't enough power to power them so i re wired them to .5 oms and they played @.5 ohms my amp gives them 700 rms. i just bought a new Vibe Blackbox Bass 5 amp that puts out 1500 rms @ 2 ohms i wired my subs to 2 ohms for 1500 rms and they didn't play so i wired them back to .5 ohms and then they played. can some 1 tell me why my subs won't play on a 2 ohm load, please my subs are not even 3 months old and i don't want to have them wired at such a low load because of SQ i would like them at 2 ohms, but they wont play at 2 ohms please some 1 explain this to me if you can thank you.
Kyblack76 Posted June 11, 2012 Report Posted June 11, 2012 Can i ask? What do you mean they "dont play" ?? No sound at all?... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
gally Posted June 11, 2012 Report Posted June 11, 2012 i guess he didnt wire it the right way http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
cloud77 Posted June 11, 2012 Report Posted June 11, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22 ohm's law. Your subs do whatever you tell them to. my guess is that it is your amp/other that was going on during your install. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
Kyblack76 Posted June 11, 2012 Report Posted June 11, 2012 @ GALLY kind of seems that way dont it?....... if he hears nothing wired at "i dont give a shit what ohm" ,... then wire's it to .5 and does, then operator error sticks out... to me SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
detroitdb Posted June 11, 2012 Report Posted June 11, 2012 Are you 100% sure you wired @ a 2 ohm load? if they worked @ .5 they will work @ 2....unless you have a bad coil....pull up woofer wiring diagram @ 12volt.com...and check..... https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U 2013 DODGE CHALLENGER R/T SUNDOWN ZV4-18 CRESCENDO 3.5K PIONEER AVIC 5300 NEX ALPINE TYPE R 6.5S & 6X9'S ROCKFORD FOSGATE 1.5" TWEETS 5 C&D TECH BATTS
Kyblack76 Posted June 11, 2012 Report Posted June 11, 2012 Are you 100% sure you wired @ a 2 ohm load? if they worked @ .5 they will work @ 2....unless you have a bad coil....pull up woofer wiring diagram @ 12volt.com...and check..... So if he had a bad coil it would still play at .5 ohm? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CHEVY4X4BLAZER Posted June 11, 2012 Report Posted June 11, 2012 Check coil resistance on each set of terminals.
Johnny248 Posted June 11, 2012 Report Posted June 11, 2012 They don't play? Don't make noise ? Have to be wired wrong... -= J-dUb =- ....no 12 step program can cure my car audio addiction...
