So just as the title says, how about Cadence acoustics? I'm trying to pick out the amp to run my basic system and I am thinking the Cadence c9. I would be running it in 3 channel mode with rockford t1625-s components for the front end and a skar 10" for the sub. But do cadence amps do rated power? How is their sound quality?
Thanks!
Link to Product for specs review ??
i, as well as a couple other people at one point used this amp. their zrs line are strong amps, and do their rated power. you wont have to worry there. as you progress to the larger amps in the series, they are 16 or 18v, but the c9 is rated at 14v.
surprisingly I haven't had much voltage drop with mine, but with both amps running, I would go ahead and do the big 3. It definitely doesn't hurt to do it, it helps the car out over all.
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
