Sean Lorbeske Posted June 14, 2012 Author Report Posted June 14, 2012 how do you post screen shots of torred calculator?
Sean Lorbeske Posted June 14, 2012 Author Report Posted June 14, 2012 i need someone to give me a ported box design for 2 kicker cvr 12 dual 2 ohm im kind of a noob and iv looked all over for a program that gave me specs and measurement but not eactly what i want i would like a box tuned to about 35hz with seperate chambers and the ports in the center of the box im limited to 13 high by 42 wide The separate chamber design is larger and heavier and has no significant advantages over the common chamber unless you are using independent amplifiers and want to avoid careful gain matching, for free I can submit you a box I did for another member a while ago: Enclosure Specifications: Fb = 35 Hz Vb = 4.5 ft^3 External Height = 13 in External Width = 39.25 in External Depth = 29.25 in Port Width = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 33 x 11 1/2 Front Internal = 31 1/2 x 11 1/2 Back = 39 1/4 x 11 1/2 Left & Right Sides: Side 1 = 27 3/4 x 11 1/2 Side 2 = 28 1/2 x 11 1/2 Top & Bottom = 39 1/4 x 29 1/4 L Port Internal Assembly Parts: Front to Back = 21 1/4 x 11 1/2 Hope it helps. the depth is a bit big it would be one tight squeeze
Sean Lorbeske Posted June 15, 2012 Author Report Posted June 15, 2012 What is the depth you have available. max i can go is 20 for it to slide right in and max width i have is 42
Joe X Posted June 15, 2012 Report Posted June 15, 2012 Changed the original post, 23" deep is the tightest I'll go and maybe it will sound a quite a bit tight.. if you can't do 23" then take the previous spec and build inside the trunk. Also you need some free airspace in front of the port (around the port width) make sure you have about that much.
Crandis16 Posted June 15, 2012 Report Posted June 15, 2012 how do you post screen shots of torred calculator? go to the window and simply press alt+screencapthen save in photobucket and use that to upload onto SMD My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Sean Lorbeske Posted June 16, 2012 Author Report Posted June 16, 2012 Changed the original post, 23" deep is the tightest I'll go and maybe it will sound a quite a bit tight.. if you can't do 23" then take the previous spec and build inside the trunk. Also you need some free airspace in front of the port (around the port width) make sure you have about that much. the trunks a good 45 deep but it tapers down and gets shorter but 23" should work great thank you i appreciate it save me some money i was gunna have a guy design and build a box for me
Gotta_LOVE_BASS Posted June 16, 2012 Report Posted June 16, 2012 its a little big but it will get the job done and can use it for future systems Be Happy With What You Got
412 CVX Posted June 16, 2012 Report Posted June 16, 2012 lol @ joe x being a box designer. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Joe X Posted June 16, 2012 Report Posted June 16, 2012 its a little big but it will get the job done and can use it for future systems His max height is 13"
