rockerchris105 Posted June 19, 2012 Report Posted June 19, 2012 i will be recieving my reconed 12w7 and i want to know how and how long should i break in my speaker.
SnowDrifter Posted June 19, 2012 Report Posted June 19, 2012 0 seconds. Just play it like normal and it will break in naturally. No need for any separate process ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Sonic Posted June 19, 2012 Report Posted June 19, 2012 As mentioned above, just play it normal and it would eventually break in.
safiend Posted June 19, 2012 Report Posted June 19, 2012 Play it normal, turn it down if you start to smell coil though New build coming soon..
RivalKarl Posted June 19, 2012 Report Posted June 19, 2012 Yep screw the whole break in thing..... Current system(In Progress) 2002 Dodge Grand Caravan Subs-16 Rival Mobile Electronics C15.22 subs. Sub Amp-1 Sundown Audio NS-1(eventually 2) Mids-Undecided Mid Amp-Undecided Batteries-6 Shuriken BT140's Alt- 320amp MECHMAN alternator Tsunami Wiring
b-dubs89 Posted June 19, 2012 Report Posted June 19, 2012 over time spiders and other parts will loosen up , but there really is no break in , just play it .
ChevyBoy95 Posted June 19, 2012 Report Posted June 19, 2012 I don't know how jl recones work, but let the glue set up for a good 24 hours and just play it. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Smurfboy Posted June 19, 2012 Report Posted June 19, 2012 Each time I get brand new speaker(s), I always give them the time to break in to be more safe and healthy. I'm not one of the guy who likes to crank up as soon as I get new subwoofer, though. That's just me.
MrSkippyJ Posted June 19, 2012 Report Posted June 19, 2012 Subs break in because you are using the soft parts. Only way to use the soft parts is to... you got it, play em loud! If you aren't playing them fully, you are simply lengthening the break in process. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Hugh G. Rection Posted June 19, 2012 Report Posted June 19, 2012 i like to play my subs free air for a few minutes at 20hz, to loosen the suspension. after that, i put em in the car and i give em hell. Owner of BigAss Ports
