Miguels Posted June 20, 2012 Report Share Posted June 20, 2012 buy two of these and run 2 subs on each http://www.ebay.com/...#ht_3394wt_1396 edit. not those but just an idea my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 20, 2012 Report Share Posted June 20, 2012 I can't think of any lower powered ones at the moment, but almost all Rockford Power amps are strapable. To strap an amp, they for one need to be able to do that. When you get amps that can do it, they will tell you how to make those strap, the reason why I suggested it, is most amps can't be strapped at 1 ohm, normally 2 ohms. Which is exactly what you are looking for as a final ohm load. You could possible just pick up another of the exact same amp that you currently have and just gain match the amps to make sure they are identical in output. if he gets 2 amps might as well just run 2 subs at 1ohm on each amp That what I was thinking, just get another of the amp hes got and run them both at 1 ohms, would be a hell of a lot cheaper. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Sanitarium Posted June 20, 2012 Report Share Posted June 20, 2012 Bridge a pair if aq1200 s and call it a day. Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2012 Report Share Posted June 20, 2012 I can't think of any lower powered ones at the moment, but almost all Rockford Power amps are strapable. To strap an amp, they for one need to be able to do that. When you get amps that can do it, they will tell you how to make those strap, the reason why I suggested it, is most amps can't be strapped at 1 ohm, normally 2 ohms. Which is exactly what you are looking for as a final ohm load. You could possible just pick up another of the exact same amp that you currently have and just gain match the amps to make sure they are identical in output. if he gets 2 amps might as well just run 2 subs at 1ohm on each amp That what I was thinking, just get another of the amp hes got and run them both at 1 ohms, would be a hell of a lot cheaper. yeah but then you have to go through the hassle of gain matching them. strapping would be MUCH easier imo since you just do the settings on the master amp and the slave amp matches them automatically Link to comment Share on other sites More sharing options...
alenv10 Posted June 20, 2012 Author Report Share Posted June 20, 2012 Well since i already have a hifonics hfi 1500 and 2 OA 15's i might as well just get another hifonics hfi 1500 and 2 more 15's They can handle 750 rms each, its just that... will 3000 rms destroy my stock alt? i dont want to upgrade it yet, but i have seen a sundown ns-1 on a stock alt with 4 batteries... NOTHING DOWN HERE YET OBSIDIAN FTW Link to comment Share on other sites More sharing options...
Smoove Posted June 20, 2012 Report Share Posted June 20, 2012 Fosgate T20001BD find a used one. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2012 Report Share Posted June 20, 2012 Well since i already have a hifonics hfi 1500 and 2 OA 15's i might as well just get another hifonics hfi 1500 and 2 more 15's They can handle 750 rms each, its just that... will 3000 rms destroy my stock alt? i dont want to upgrade it yet, but i have seen a sundown ns-1 on a stock alt with 4 batteries... i dont think those amps are strapable. plus they dont really do rated power. and yes 3000w will destroy a stock electrical system. you're looking at a high output alternator from mechman or dc power, plus a group 31 agm battery or two Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 20, 2012 Report Share Posted June 20, 2012 I can't think of any lower powered ones at the moment, but almost all Rockford Power amps are strapable. To strap an amp, they for one need to be able to do that. When you get amps that can do it, they will tell you how to make those strap, the reason why I suggested it, is most amps can't be strapped at 1 ohm, normally 2 ohms. Which is exactly what you are looking for as a final ohm load. You could possible just pick up another of the exact same amp that you currently have and just gain match the amps to make sure they are identical in output. if he gets 2 amps might as well just run 2 subs at 1ohm on each amp That what I was thinking, just get another of the amp hes got and run them both at 1 ohms, would be a hell of a lot cheaper. yeah but then you have to go through the hassle of gain matching them. strapping would be MUCH easier imo since you just do the settings on the master amp and the slave amp matches them automatically Very true, all up to this guy if he wants it to be easier, or cheaper. I have never gain matched, but trying to hit a certain voltage while adjusting gain, IS A REAL BITCH. Edit: ^^^^ yes, you will need to get a H.O. alt, and more than likely a upgraded front battery accompanied by a rear battery. Depending on what you can fit upfront. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
donpablo Posted June 20, 2012 Report Share Posted June 20, 2012 http://www.powerbassusa.com/xta-5000d 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
alenv10 Posted June 20, 2012 Author Report Share Posted June 20, 2012 Well if the hfi 1500 arent giving out rated power than thats perfect, 1200 rms is exactly spot on, but... Stock alternator with 2 hifonics hfi 1500's with 3 Batteries, bad idea or will i manage? NOTHING DOWN HERE YET OBSIDIAN FTW Link to comment Share on other sites More sharing options...
