2nd time. Same Problem, Bout To Give Up! Subs Cutting Out!
Please Read Whole Thing Before Saying Something Stupid,
Problem - Subwoofer cutting out at high volume!
Subwoofers - Four 12" Swr-1243d 600rms
Amplifier - Mrp-M2000 2000rms Gain & Bass Boost set as lowest point
Alternator - 270xp Dc Power
Batteries - One Yellow Top Optima Main Battery - & One Kinetics Hc600 Trunk Battery
Voltage Drop - Lowest Point Hits 13.0v aplifier recomend 14.4v
Ground - A gold battery post ran threw the car "paint removed" with a 1/0awg wire outside running to frame so to points of contact.
Wires - All 1/0 Monster Cable with 200a fuses in place. Big three done.
Headunit set - Bass +1 Mid 0 Treb +3 Sub +15 Maxed - Norm Vol 22
So what the f&%^ is going on why the f**^ is my s*%^ still cutting off its pissing me off so much i want to burn my care to the ground no matter what i set my amps gain it keeps happing at random times it driving me insane and yes all my wires are tight Sombody help please!
Random times? Not just full tilt?
Try this: run a wire from the + on your amp to the remote turn on on your amp so it's always on. If it works fine, your remote wire is wonky or you might need a turn on relay
What load are you presenting to the amp. If you don't know we've found the issue
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
^ good question
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Could also be a bad woofer or a woofer seeing a short.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
