Metals to use for a Bus Bar???
Im making a bus bar for my batteries and im using a aluminum bar and the bolts i bought are Zinc plated. Ive heard people say to use stainless steel but when i looked up the conductivity ratings for Zinc and Stainless steel, Zinc is over 20% higher on the scale for conductivity? what is better to use and does it matter for signal too because i used Zinc plated bolts for my speaker terminals.
149.4 Db @ 30Hz Outlaw With One 15" Fi Team Sub, Trunk Build. !!!!!Hair Tricks!!!!!
Check Out The Build Log http://www.stevemead...0-4-and-t400-4/
Watch The Videos http://www.youtube.com/user/jcplaya3
Zink should do fine. A lot of people use stainless, but brass is what I noticed Stinger uses on there terminals and circuit breakers.
But yeah what you have should do just fine.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
solid gold
sure that will be cost effective.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Aluminum or copper.
X2, these are going to be the most affordable choices. Silver would actually be the best metal to use, but it corrodes and is expensive.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
solid gold
Also worse than copper and silver for resistivity.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Stainless and brass are least corrosive.. but also more resistent... I use aluminum flat stock 3/8x2in and 5/16x1/12 zinc bolts and haven't had any issues
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Your bus bars should fit firmly against the lead terminal of the battery and the majority of your current will flow from that junction. The bolt is just to hold them firmly together. But going brass or zinc coated is just fine
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   1 Member, 0 Anonymous, 1697 Guests (See full list)
