Metals to use for a Bus Bar???
lol just use aluminum. it works and plenty of people use it. and its cheaper than copper
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
  • 5 months later...
I am looking at making my own buss bars, however due to the orientation of my batteries I have to use bends. I am looking at .125 thickness/.5 width copper flat bar, I could also use the same in brass as they are relatively close in price. My question is which metal will be better and easier to bend, these will be simple 90 degree bends and I thought of using a butane torch to heat up the bars for the bending if needed depending on the bars flexibility at this thickness.
Hopefully someone will chime in here.
Thanks
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Copper over brass all day plus it's alot softer an easier to bend
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Thanks
Hey man, don't post here often but i know some things about conductors that'll help you. I'm not sure what your running but you would probably want bigger bus bars. Those dimensions would give you a size that is equal to a wire that is slightly smaller than a 2 AWG wire. I would double the area of your bar, as this would make it have similar conductivity to something like 2/0 wire.
If you have any questions about this stuff, just ask i'll be glad to help :)
solid gold
sure that will be cost effective.
solid gold
hell Yeah!! If the price of gold goes up that is....
  • 7 months later...
I ended up going with solid copper. I found a company called Strom Copper that makes them up already for grounding and they are CHEAP for complete sets!!!!
Did you use stainless steel nuts and bolts on that copper bar?
  • Who's Online   0 Members, 0 Anonymous, 1398 Guests (See full list)
