the ones i can get are powersafe batteries, made by enersys, tell me a little bit more about your batts, how mane of them? what's your voltage drop?
I've used UPS batteries with success
wich model?? i can find the enersys 155 around here CHEAP as hell, they are 150AH , i've never used them before and lots of people say they do pretty good, an xs power D3100 cost around 400$ over here, i can find those UPS batteries for like 100$ a piece
If they are cheap why dont you test them yourself and give us a review.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
as much as i love the idea of testing them, i don't think i would spend 100$ on that just for a test, BUT, you actually have a point, let me see if there's someone that can borrow me one of those batteries and actually gonna test it against a D3100 i have laying in my closet :)
4 of the enersys npx-150s
I could hold 13v running 3500 watts on music with a 110(clamped) alt. But that was with the gain turned down on my old build.
They are chilling out in my garage right now. I can hook them up and tell you my results if you want me to test them a bit
honestly it would be a great help, but i actually didn't thought about asking someone to borrow me one of the exact model i can find around here and test it against a D3100 , if you do a similar test please send me some results, it would be awesome, i'm actually gonna try to do it myself this weekend also :)
2 147ah, and a 78ah, 200a alt. running about 4.5k (highs included)
full tilt from 14.2 to 13.8v (at idle)
14.2 to 14v 1200rpm
C&D and Powerware (which i think is a C&D essentially) around 100lbs each.
Go to 3:28, voltage is a bit higher because truck wasnt running long. but 14.3v to 14v full tilt on a low 30hz note. (AT IDLE, so around 125amps from the alt)
Edited by ChevyBoy95
very nice man, thanks for the input!!
If you're looking to use yellow/red tops be careful.. they do gas off just like water based batteries:
Hammerdown... 1%
Never knew that. Man i learned my fact for today.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Im lookin for cheap batteries. Here's what im tryin to use them for if it helps. 4-18's Obsidian Audio D4's, 25.28 cu ft box tuned to 32hz. 2 Planet Audio BB2400.1 strapped at 2 ohms. 8 gauge speaker wire for subs and 0 gauge wire for power and ground. Big 3 upgrade and stock alternator for now. I know i should run like a XS battery but low on funds at the time. I can get the XS D3400 for $260 so im lookin for a battery that is close to it for less money.
  • Who's Online   0 Members, 0 Anonymous, 1961 Guests (See full list)
