Sub enclosure shape
cheebs
May be worse for an 8" but take a look at some SA-12 plot ported vs sealed:
And the ported box on a SQ alignment tuned really low, if you use a power alignment such as those used in car audio sealed looses for a wider margin, there is IMO no point in going with sealed when you have the space for ported.
i don't want to use a sealed box but as i said before i want to understand why it works or don't work.
ok i m reading as much as i can and trying some things. i found the Torres calculator and i played with some things and came up with this. tell me how this would or won't work.
height - 8
depth 1- 10
depth 2- 13
width - 33
one port 4" wide and 18" long
the calc. says i will get a gross volume of 1.36 ft3 with a tuning of 36.57hz
is this right?
ok so here is what i need to know if i invert the sub and have the port outside how long and wide does the port need to be per sub? here's is what i am thinking. i would like to build 2 boxes each .7 cuft . the sub will be inverted so no displacement and tube ports outside the box no displacement. once i do that i can fiberglass the whole thing in the shape i want.
  • 3 weeks later...
so since i always see these post when people ask questions but i never see what they ended up doing i thought i would post what i did.
why exactly does jacob not recommend a sealed box for the sa-8 v2 but has a spec for it on the sundown site.
they give you sealed recommendation for use in the sealed section of a 4th order more than for just running a sealed enclosure...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
sorry i did not get the pics of the beginning of the box but when i get working my mind goes to auto pilot.
the cone in the middle is not included in the box volume. and the net volume is 1.26cu ft with a 4inch aero that's 24" long from end to end give or take an inch.
Thats some nice work, looks great.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
