theres a local welding store that sells welding cable and thought about running that for my big 3, how good is there wire and is there a difference from this and car audio wire?
I wouldn't run anything else ... cut your cables to the length you need and take them back to the welders and get them to install connectors for you ... They may not know what you plan to do with the cables, but they are masters at installing connectors ...
apply some shrink tubing, and your golden !!
i'd use it for multiple runs from a battery bank to amps, but be careful under the engine. most likely not able to withstand the heat in certain spots. sure it CAN work...but like i said, just be careful with it
thats what welding cable is for !! it withstands heat ... welding cable is good for +105C ... i use a mapp as tourch to solder lugs onto welding cable and you cant even touch the wire when done but the jacket doesnt even melt !!
this for sure. Not sure why some people think it will melt faster that car audio brands.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
i used welding cable...
i had a 6" section left.. i used a torch on it for a good minute to see if i could melt it.. no dice.. tried getting it hot and rubbing the jacket off... no dice
i ran it next to my headers on truck.. about 3/4" away and have no issues
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
The heat probably wont do anything to it but if its rubbing it could cut through and short out. I use welding cable and it works badass I recommend it.
  • Who's Online   0 Members, 0 Anonymous, 1050 Guests (See full list)
