Eckogwear72 Posted August 9, 2012 Report Posted August 9, 2012 i found out when i excelerate fast or take a corner fast my power wire to my amp blows a fuse witch is fustrateing any ideas of why this would be happening?
dkindle613 Posted August 9, 2012 Report Posted August 9, 2012 you have a short somewhere.. that would be my guess WARNING: I speak 4 languages, profanity, English, sarcasm & real shit 2003 ford explorer 2 RF T1 D4 15s in a 6.8 cubic ft box 1 T1500.1bdcp 250amp ALT by Mike Singer 2 runs of 0 gauge 3 yellow tops
bass_stalker Posted August 9, 2012 Report Posted August 9, 2012 by any chance is your amp mounted? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Tebo Posted August 9, 2012 Report Posted August 9, 2012 you have a short somewhere.. that would be my guess if it pops when he speeds up it isnt a short. It would pop as soon as you put the power wire in the amp 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
SmallTruk Posted August 9, 2012 Report Posted August 9, 2012 you have a short somewhere.. that would be my guess if it pops when he speeds up it isnt a short. It would pop as soon as you put the power wire in the amp No it wouldn't. He said it pops when he accelerates or takes quick turns....both actions will cause things to move in ways they usually wouldn't when the car is at a stop. Check the connections on the amp for anything loose that has enough play to make contact with a ground. Check up by the battery too
the rock Posted August 9, 2012 Report Posted August 9, 2012 Maybe some where on you power wire pinch. Check your power
imnew59585 Posted August 9, 2012 Report Posted August 9, 2012 what is your size of power wire? what is your amp, and how big of a fuse do you got?
ChevyBoy95 Posted August 9, 2012 Report Posted August 9, 2012 i would check for loose wires, loose strands even, and make sure the power wire is secured firmly. After that check for pinches that might have punched through the jacket and possibly shorting. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
dkindle613 Posted August 9, 2012 Report Posted August 9, 2012 you have a short somewhere.. that would be my guess if it pops when he speeds up it isnt a short. It would pop as soon as you put the power wire in the amp what if the amp or wire move around every time he speeds up or goes around a corner. wire touches another wire, or wire touches metal some where???? WARNING: I speak 4 languages, profanity, English, sarcasm & real shit 2003 ford explorer 2 RF T1 D4 15s in a 6.8 cubic ft box 1 T1500.1bdcp 250amp ALT by Mike Singer 2 runs of 0 gauge 3 yellow tops
