Omega5002 Posted August 16, 2012 Report Posted August 16, 2012 My bad..., thought it was a 12' Anyways, a proper ported box will sound better than a sealed box when built and tuned correctly. Quote 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
QuinnyGT Posted August 16, 2012 Report Posted August 16, 2012 A sealed box isn't going to give you much below 35-40hz anyway. Build a ported box tuned to 30-33hz you will get the lows you want and it will still punch the higher notes some bit.! I had one of these in 2.7suft tuned to 32hz off 1.5Kw and it was a pretty musical box, maybe a little small but musical. I sold it and 2 years larter its still goind strong Quote Source: Alpine 9886R, Audiocontrol Epic 160, Alpine PXE-H650 processor, Line driver Front: 2 sets 7" AA componants with tweets Amp: SPL Dynamics 4 Channel, 1,200 Wrms output for doors, new amps coming for subs Sub: Ascendant Audio Mayhem 18's *2 So Far: 149.9db @30hz
412 CVX Posted August 16, 2012 Report Posted August 16, 2012 (edited) Good luck fitting those back there in anything more than a sealed box. Your best bet is to sell those and get a pair of decent 12s or 10s depending on your trunk space. Bet they'd sound a hell of a lot better than those 15's. edit: just saw your dims. from the looks of your trunk, you're gonna have to build the box inside the trunk. you won't be able to get it out of the trunk that way. pair of 12's will sound better than the 15's you have once you build a proper box. Edited August 16, 2012 by 412 CVX Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
ear2ear Posted August 16, 2012 Report Posted August 16, 2012 12cu ft in the back seat of a Jetta? You should measure it and the port and post your dimensions here. This is going in the trunk, not the back seat. Since you asked for dims: 17" tall, 37.5" wide, 39" deep. Yes, i've measured. It will fit. My bad - reading > me So even with enough room in the trunk, there's not enough room on the baffle for a port. Anyway, what I meant originally was measure the current box and these guys might tell you why it sounds the way it does. Quote '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
n8ball2013 Posted August 16, 2012 Report Posted August 16, 2012 you have no low end because you have massive cancellation and kickers dont exactly reach down and jiggle your balls anyways. I cant see you fitting them in the trunk. even sealed. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
SlamminBeats Posted August 16, 2012 Report Posted August 16, 2012 you have no low end because you have massive cancellation and kickers dont exactly reach down and jiggle your balls anyways. I cant see you fitting them in the trunk. even sealed. LMAOOOOOOOOOOOOOOO Quote
n8ball2013 Posted August 16, 2012 Report Posted August 16, 2012 I keep it real. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
SlamminBeats Posted August 16, 2012 Report Posted August 16, 2012 i see that for real though, i remember kickers never doing jack below 40 hz 40 hz!!! thats not even bass yet! Quote
Sergeant_Skyrim Posted August 16, 2012 Report Posted August 16, 2012 you have no low end because you have massive cancellation and kickers dont exactly reach down and jiggle your balls anyways. I cant see you fitting them in the trunk. even sealed. I beg to differ. I've got one of my old Kicker Comp 12s in my 2.2 cu ft. box for my ZCON tuned to 31Hz and Rack City still jiggles my balls. And I surprisingly haven't blown it with my BRZ2100 yet Quote Build in progress
SlamminBeats Posted August 16, 2012 Report Posted August 16, 2012 i feel like we may have different interpretations of balls jiggling Quote
