TeamHT Posted August 28, 2012 Report Posted August 28, 2012 most of the time not always it is 3x the wired nominal so if wired at 1 ohm you can expect rise to 3 ohm. It is statements like this that just cause more confusion on what "impedance rise" actually is and what it means to people building everyday music systems. . . I think "it" and "is" is backwards, and "can" is supposed to be "can't" Tell me...does this smell like chloroform to you?
TeamHT Posted August 28, 2012 Report Posted August 28, 2012 OP, take a look and see if you got an AA dealer around you, that's my personal opinion, lol Tell me...does this smell like chloroform to you?
Jessica Posted August 28, 2012 Report Posted August 28, 2012 Rise isn't always bad, I may be wrong but in ported enclosures you will likely see lots of rise at tuning. But your subs will move less and the box does most the work. It ends up being more efficent since you are making less power but getting the most output. There are lots of other factors involved and that is kind of a blanket observation. But you get the point right? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
dog24fret Posted August 28, 2012 Report Posted August 28, 2012 Is rise important to learn for daily music? Or is it more for comps like the OP I am still learning this subject. Cowboy Escort GrAnny ThUmper The Burp
bkolfo4 Posted August 28, 2012 Report Posted August 28, 2012 Is rise important to learn for daily music? Or is it more for comps like the OP I am still learning this subject. Don't worry about it. The impedance does not just "rise" because you put the woofer in a box. At Fs, the woofer has what is probably the largest impedance spike in the system and it occurs even if the woofer is sitting on your kitchen table. . .it does not mean you lose output at that frequency or need to have a lower impedance driver. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
dog24fret Posted August 28, 2012 Report Posted August 28, 2012 Is rise important to learn for daily music? Or is it more for comps like the OP I am still learning this subject. Don't worry about it. The impedance does not just "rise" because you put the woofer in a box. At Fs, the woofer has what is probably the largest impedance spike in the system and it occurs even if the woofer is sitting on your kitchen table. . .it does not mean you lose output at that frequency or need to have a lower impedance driver. Thanks. Wanted to make sure it wasn't something else I've not done right. Or something that would've help any system sound better. Cowboy Escort GrAnny ThUmper The Burp
bkolfo4 Posted August 28, 2012 Report Posted August 28, 2012 I should clarify my last statement - A subwoofer will have additional impedance spikes once it is in the enclosure caused by additional resonant frequencies of the system. There are actually spikes on each side of the port tuning frequency, not at the tuning frequency. The driver being at minimum excursion is a reaction with the Helmhotz resonator, not an impedance spike. And the size and distance between these spikes has to do with several factors such as the tuning frequency vs. the drivers Fs vs. the natural resonance of the enclosure. That is why different enclosures will produce different impedances for a given subwoofer. The point I was trying to make was that there is still a major impedance spike with the driver not even in the box, and a sub does not just go from being a dual one ohm sub to a dual 4 ohm sub after being installed in a box. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
DubNDodge Posted August 28, 2012 Author Report Posted August 28, 2012 OP, take a look and see if you got an AA dealer around you, that's my personal opinion, lol Ok, thanks will look some more. But what do you think would be better for that space? 2 12s or 1 15. Or just does it depend on quality of the subs. I know the 12's will generally have like 50in2 more than the 1 15 but don't 15's have better excursion? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
HHR Ed Posted August 28, 2012 Report Posted August 28, 2012 For 99.98% of people in car audio, Impedance rise is nothing to even have in your brain. Don't worry about it, don't try and adjust your voice coil resistance to compensate for it, don't try and tune for it. Just go about your day wiring a 2ohm load to your 2ohm stable amp, and build your box according to recommendations. If you are a hardcore SPL competitor, and you may have some understanding of electronics, then by all means have at it. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
DubNDodge Posted August 28, 2012 Author Report Posted August 28, 2012 For 99.98% of people in car audio, Impedance rise is nothing to even have in your brain. Don't worry about it, don't try and adjust your voice coil resistance to compensate for it, don't try and tune for it. Just go about your day wiring a 2ohm load to your 2ohm stable amp, and build your box according to recommendations. If you are a hardcore SPL competitor, and you may have some understanding of electronics, then by all means have at it. Thanks! that video helped me understand the concept a lot more '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
