DustinBolt Posted August 26, 2012 Report Posted August 26, 2012 would you run 2 12s with say 28mm of excursion or 4 10s with 20mm of ecursion? 1997 BMW 528i Fi ssd 12 6th order box Build Log- http://www.stevemeadedesigns.com/board/topic/144835-rebuild-in-the-bmw-6th-order-time-update-1113/
Socky Posted August 26, 2012 Report Posted August 26, 2012 in this case the 4 10s. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
safiend Posted August 26, 2012 Report Posted August 26, 2012 4 10's for sure. Way more cone area New build coming soon..
Emmet Posted August 26, 2012 Report Posted August 26, 2012 Can always check how much air the subs move too by a simple calculation (sd) * (xmax * 2) to have a rough guide. But at the end of the day, real world > theory. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Swordlordboy1234 Posted August 26, 2012 Report Posted August 26, 2012 In b 4 lock! assuming they have the same RMS power handling then the 10's but for less space, more simplicity, and possibly the same RMS handling... id go the 2 12's. 4 10's might be louder and cleaner but the problem is, its more things that might fail, and it sounds like they are of lesser quality then your 12's. Also a box design for 2 12's is easier then a box for 4 10's... assuming were talking the ideal box... because less variables. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
DustinBolt Posted August 26, 2012 Author Report Posted August 26, 2012 I was just using the 4 10s or 2 12s as an example, I just wanted to know which u would consider as more important 1997 BMW 528i Fi ssd 12 6th order box Build Log- http://www.stevemeadedesigns.com/board/topic/144835-rebuild-in-the-bmw-6th-order-time-update-1113/
bre2ts Posted August 26, 2012 Report Posted August 26, 2012 depends on which subs on whether thats one way xmax or combined what kind of power vehicle location so many things to consider Feedback 1 | Feedback 2 you win some, you lose some
Joe X Posted August 26, 2012 Report Posted August 26, 2012 would you run 2 12s with say 28mm of excursion or 4 10s with 20mm of ecursion? 2 12s 28mm = 2968 cubic centimeters of displacement 4 10s 20mm = 2640 cubic centimeters of displacement For each option you would need to put whatever power it takes to reach Xmax. You need to make your mind on why you want to do one over the other.
bkolfo4 Posted August 27, 2012 Report Posted August 27, 2012 Basing your sub decision on Xmax alone is dumb. Good example: RE XXX 12 vs. Fi BTL 12 XXX is almost double Xmax and would not hang with a BTL. Displacement is not the only parameter of a subwoofer. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
DustinBolt Posted August 27, 2012 Author Report Posted August 27, 2012 Basing your sub decision on Xmax alone is dumb. Good example: RE XXX 12 vs. Fi BTL 12 XXX is almost double Xmax and would not hang with a BTL. Displacement is not the only parameter of a subwoofer. Basing your sub decision on Xmax alone is dumb. Good example: RE XXX 12 vs. Fi BTL 12 XXX is almost double Xmax and would not hang with a BTL. Displacement is not the only parameter of a subwoofer. thanks thats the kind of information i was wanting to hear. 1997 BMW 528i Fi ssd 12 6th order box Build Log- http://www.stevemeadedesigns.com/board/topic/144835-rebuild-in-the-bmw-6th-order-time-update-1113/
