bighoss' 2006 f150, truck is gutted
Not really a rebuild just beefier subs and more power
True enough, I remember reading that earlier now that you say it.
Give me your Paypal and I will chip $5 towards shipping if you go with Mayhems........just sayin.................................................now what
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Sweet. Only $495 to go lol. I'm gonna go with the hems unless I can get the tantrics for a lot cheaper
Used to have a loud truck
call ronal murphy up tell him what your doing hes a good guy, he will work with you
I still have a few months to think about it but a good think about tantric is I could go pick up the subs and save a ton on shipping
Z v4s like small boxes and hive a flatter response caparitively in this case I would have to agree with the mahems unless you take up some space inside the box to make the z v4s happy ... plus both woofers could probably take a 3500 daily no problem
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Lol. Xfls can get low as shit. No team 12"s though. Give me the $16,000 for it and ill do 8 5500's and 8 shd 12's instead.
First off kick ass log man thanks for posting it and great job it looks bad ass! :D
Reading through all of this without anyone bring up the issues with electrical has been driving me nuts for like 20 pages... ;) I didn't want to skip to the end in case it was fixed (plus I wanted to see it all anyways).
Few things...
1) I would have 8 1/0 runs (6 if you have 2/0) to the rear bank. 4x350 = 1400a of max draw... so bare minimum 6 1/0 OFC (and spread them across the bank don't put them all in the same spot)...
2) The last pic I saw only had 1 ground run from the alt. You should have a matching set of grounds from that alt to the frame that you have power in the rear. Run all grounds to the frame front and back then ground the front battery to the frame as well. Another option is adding a bus to the front battery and running everything to that (alt to batt buss - bat buss to frame).
3) When you see the discrepancy from your front batt to your back it's because the back bank isn't charged. AGM sits 12.7-12.9 depending on the brand, but generally speaking if it's sitting 12.5 that's like 75% full... Your charger is not big enough, mine could barely keep my 3 3400's up to snuff and when I went to 6 it didn't stand a chance. You need a bigger charger because while it might be able to get a surface charge up they aren't actually fully charging off of like .15a per battery (I have the same charger and I think it's 3a? So whatever 3/# of batts you have is).
Get a better charger, add some runs, and watch the magic happen ;)
Again just trying to be helpful, love the build man!
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
I know the electrical us weak, this is damn near the same wiring from when I was running 6k lol. A few pages back I said I was.gonna do the electrical before I.do anything amp wise. I'm keeping the same batts and my singer 350 but will be adding 2 mechman 320's and do the wiring. I know I'm gonna catch hell for saying this but I'm either going with 3+ and 3-runs of shca ofc 2/0 from the front batt and 1 run.to the back from each alt or 12+ and 12- runs of execution audio cca 1/0 from the front batt but I'm sticking with ofc for for the alt runs and the runs to the amps. I havemt had any problems with the small charger. After a few days on the charger they rest at 12.9-13.1.
