CodyLucente Posted September 12, 2012 Report Posted September 12, 2012 I have Dual 2Ohm DVC subs that can run at 8, 2, 0.5 ohms 1500w rms each. I have no prior knowledge in this area and would like to know the effects of using low impedance such as 0.5 ohms on my system and what do you recommend? Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Lbox88 Posted September 12, 2012 Report Posted September 12, 2012 Run it at 2 ohms, 0.5 is stressful on the amp and your electrical system which is not enough to support 1/2. UBL | Build Log
C-Fizzy Posted September 12, 2012 Report Posted September 12, 2012 I recommend not doing it. Find an amp that outputs 3,000 watts at 2 ohms. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
Kyblack76 Posted September 12, 2012 Report Posted September 12, 2012 No... With out even knowing your set up... Run at .025 ohm... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CodyLucente Posted September 12, 2012 Author Report Posted September 12, 2012 The only reason i wanted to run at 0.5 ohms is because it is hard to find an amp in my price range at 2 ohms. Do you guys have any recommendations? anything over 2200watts rms would be great. Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
CodyLucente Posted September 12, 2012 Author Report Posted September 12, 2012 Did you mean .5 or 2 No... With out even knowing your set up... Run at .025 ohm... Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Kyblack76 Posted September 12, 2012 Report Posted September 12, 2012 I ment.... PLEASE RE THINK SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
tacomaguy1 Posted September 12, 2012 Report Posted September 12, 2012 Real men wire below .5 Nothing wrong with it if you have the proper electrical Team Flex Issues
Audio Customs Posted September 12, 2012 Report Posted September 12, 2012 The only reason i wanted to run at 0.5 ohms is because it is hard to find an amp in my price range at 2 ohms. Do you guys have any recommendations? anything over 2200watts rms would be great. i would try to find a amp that are strappable and run it @ 2 ohms if u have the $$$ to do it . but i WOULD NOT run @.5 cone area http://www.stevemeadedesigns.com/board/topic/6819-cone-area-of-a-subwoofer/ 4th order band pass basic http://www.stevemeadedesigns.com/board/topic/126478-basics-of-a-4th-order-bandpass-enclosure/ this is Torres box calculator My GUI Box Tuning Calculator Download - Updated 8/18/2012
FknCrawler Posted September 12, 2012 Report Posted September 12, 2012 I have no prior knowledge in this area I would run at 2ohm to be safe unless you have the electrical to back up .5ohm. 1992 Honda Civic CX Hatchback K24a2 Swap
