Little System I did over the weekend.
Buddy of mine wanted to do a little system in his GF's car. So after collecting the gear, he finally dropped off the ride. Had Will come over and lend a hand on it, so he could help me fuck some chit up :D
Now typically when someone says they have everything to do an install, they might have 60% of what is really needed to do the job. My hats off to Randy for covering 95% of everything needed to do the job.
We started off with a simple Pioneer deck with steering controls.
Then added Some Crescendo mids to the doors. Over all I liked the product, however the speaker terms were a huge mis-step IMO. What we ended up doing to get them to clear was remove the push terms and do a direct lead
Next since it's a chicks car, we had to add some bling. Simple little acrylic ring with pink led's
Next we worked on running Power wire back to the amps. The Install kit can with runs of 4G plenty for the system. Found a grommet to poke the runs through. ended up running the wire in the frame rail to the rear seats.
Found a nice spot to put the fuse holders.
Simple mdf base, sealed, primed and painted.
Next part was to run the big 3.Not too hard to get too.
Also grabbed at the alt for the ground.
Now onto the battery connections. I had to mod one of the terms to work with the factory connection. It had a fuse block setup on it that I didn't want to me with.
After a little Second Skin added to the trunk and lid, It was off to the amp rack. Decided a resverse mount would look cool.
wrapped it in vinyl
Didn't get any of the box building. Nothing crazy about a single 15 and a pair of Aero ports. Did a front fire on it.
Then a little bling on the amp rack.
Took apart the bass knob to give it a personal mount.
The center console works.
Last was to add tweeters and some xovers.
These Soundstream ones aren't too pretty too look at. So it was time to try to hide them.
If you cut off the case you have a few options.
Got it to mount in the factory mount.
Little CA glue and its a wrap.
Then did a sim[le plate foe the x over.
Mounted in a dead spot behind the door panel.
So that's it for now. When it comes back I will add a little monogram picture on the back of the box. I need to find a sticker guy to do it. Then do a cover from end to end to cover the box and open space around it.
:fing34: :fing34: good work as always
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
