Do you weld for a living? I only been doing it for a year. I like it so far
I wasn't trying to say your wrong, I heard that welds where not good, looks like i heard wrong
I do not weld for my daily job but I have made money from welding. I am a mechanic. I have also built aftermarket Jeep parts that rely heavily on how well I weld. Including the winch mounts on my jeep I just sold.
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
If it were my car i would sand a bare metal spot on that bracket and put a clean bolt in and call it good. Metal 2 metal ftw.. If that isnt possible on that spot find somewhere else to ground to. Most people on here like using a bolt on the strut tower. I like anywhere structural that I can sand to bare metal.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
Big 3 helps in a big way as well. It is not a cure all but a Big help.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
Ok i will record all of my headunit settings (disconnecting the battery deletes them) and then see what I can do with it. Still not a hundred percent sure if it is welded. It is ground that came with the car. I will take pictures of the progress.
id leave it alone and consider it a factory ground and find better ones for the hrest of my runs.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If that is a factory ground spot, I'd leave that in tact like n8ball2013 said. But I would find a large enough, flat spot where a ring terminal would make full contact and sand it down so it's metal-to-metal. Pretty much what the consensus is on that. I always try to make as much contact with the ring terminal as I can, because why would you only want a small part of the ring terminal touching? Doesn't make any sense ya know? Good luck though!
Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!)
Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2
Speaks: RF T2652-S 6.5" and RF T1692 6x9"
Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's
Wiring: Kolossus Fleks Kable 1/0 (2 runs)
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
