Amp and sub getting hot
I have had a Rockford R500-1 for over a year now, I sold the 2 P1 12" subs that i bought when I bought the amp a few months ago
today i bought a P3 15" 4 ohm dvc and I wired it to 2 ohms, everything was working fine and about a hour into having it installed I started smelling hot plastic, so upon inspecting the amp it was hot to the touch so I pulled the sub to make sure it was wired correctly and the back of the sub was pretty hot also. If anyone has any idea what could be the issue I would appreciate it.
07 Dodge Caliber
15" Rockford Fosgate P3
Rockford Fosgate 750-1D
Pioneer DEH3500
clipped signal can heat up any sub even if its underpowered
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
low voltage and clipped music.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
What was the nominal impedance of the old subs, if it was 1-ohm, switching from 1 ohm to 2 ohm, will be effected differently by the gain. Should reset gains when ever there is a sub change.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Thank you, this seemed to fix the issue
07 Dodge Caliber
Pioneer DEH3500
Your gain might be a little to high, how did you set it? Your shouldn't be having that much voltage drop with 500rms but playing clipped music isn't good esp if your signal is already clipping
youre trying to power a 1000ish rms sub with a "500" rms amp?? im assuming your gains and bass boost were all the way up
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
