I'm getting rid of my Pioneer P4000DVD which has served me well for the two or three years I've had it. I paid $300 for it and besides one of the pico fuses blowing out, it was pretty darn good. But now, it's time to replace it.
Tablet: Acer A100 (w/ ICS)
EQ: Clarion ESQ746
Volume Control Knob: Pac Audio Lc-1
OBDII Reader: Excelvan ELM327 v1.5 Bluetooth Mini
Switch Panel:
The former bass knob, will now become the tablet volume control. The tablet will output to the LC-1, then the LC-1 wil go to the input on the EQ. The first switch will continue it's function as the on/off for the bass amp. The second switch will be the power for the charger for the tablet (hopefully I'll automate it at some point). The third switch doesn't have a function just yet, but I'm sure it will as I continue with the build.
Pre-existing:
2 Apline Type R Subs
HIfonics 2008D on subs
Hifonics TXI6006 on front components (rear speakers not amped)
Ground loop isolator
Turn-on delay (for thump)
Deka 9a31 battery (will definitely need two batteries now)
As for mounting the tablet, thanks to some advice from a co-worker, I've finally came up with something, but I'll just update it as I do it.
vid above on photobucket
*all wires have been cleaned up (except the RCA's) as I haven't finished with them yet. Hopefully, I'll be getting the case that I'll be mounting in the dash area tomorrow. Everything (the ash tray, the shifter bezel, etc...) will be sanded and repainted after everything is in place and working correctly.
Learning Everyday.
Pioneer AVH-P4000DVD
Alpine SPS-610C
BXI-2008D
(2) SWR-1242D / Ported
I thought bout doing this but I have the a500... 10" way to big for my dash.... more pics?
I guess the screen size is dependent upon how big your dash is. I've definitely seen people on the net with 10" tablets in a magnum.
Hows the quality through the aux cable?
EDIT: Doesn't the EQ have a main volume knob also?
As far as my ear, the quality is pretty good. It's as least as good as my previous setup, if not better because of the EQ. Yes, the EQ has a knob, but the EQ is under the arm rest. Not to mention, that knob is small and hard to manipulate.
I've read about the bluetooth option, but the limited research that I've done has yet to yield a reasonably priced bluetooth receiver that will auto connect with my tablet. Any suggestions would be great.
Learning Everyday.
Alpine SPS-610C
BXI-2008D
i can connect my tab to my head unit just fine in my daily once its synced. you just have to make sure your bluetooth is on and then select it as a source.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This is exactly how I do it. Since I'm keeping my tab removable, all I gotta do is have my BT on and it automatically syncs up with the HU and starts playing as soon as I pick a song. And it's all hooked up to the EQ so I can use that as my main volume knob. To my ear, I can tell little to no loss of quality on bluetooth. Auxiliary cable I can tell though.
Tuned in for how this turns out man. Looking like some good progress so far!
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
^^^ So with no head unit, a basic A2DP module will work? (like the one in the link? just use the aux out on it and go to the EQ or even a Bit one, etc.)
It should, I am using a RF 3sixty.3 to play my Nexus 7
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
I've seen plenty of folks relocate their head units and still use those, but I was about done with my p4000. A pico fuse had blown and it's just old....but it certainly got the job done. I don't know if it would auto connect or not, but since I'm taking it out completely, I need another solution.
Today I got my leather case in, which holds in the tablet at the four corners (more like a case). I'll be mounting that case to a piece of wood or other material covered in suede or some other material, cut to the void left in the bezel. Then I plan on making some sort of bezel to sit just over the side of the tablet.
Unfortunately, I'm working 14 hours days until Wednesday, so I won't be able to work on it until then. Ah well, more money for an extra battery and a new 4ch. amp.
Learning Everyday.
Alpine SPS-610C
BXI-2008D
