I just wanna know are those BIG external hard drives any good? Plus can I store my private info like: personal PC settings Email, Pics, music, and etc on it if I decide to "clone" my hard drive thats in my PC now?
THE GRADUATE 10:18:2007
the only problem with external HD is there is a slight bit of lag between it and the computer due to using the usb port but other than that they are very useful
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
How bad is this "lag" and how will it affect my Pc if I use one?
my friend told me not to install games or stuff on it but musci is fine.
im not sure ive never used one myself
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Actually they work really well. also im sure your friend never tried installing a game on one because i have installed countless games on mine and there is no lag. the "lag" he was talking about is prolly just the time it takes for the hard drive to spin up to speed but thats only like 2 secs and its not very noticeable.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
yeah just keep large file quantities to a minimun. it'll make it crash. just do lots of small files
To Slide Sideways Or Not To Slide Sideways?
Head unit: Pioneer AVH-5000DVDSpeakers: 4 Pionner TS-G6842R Amplifier: Alpine MRD-300Subwoofers: 10" JL
ummmmmm ok how are large files going to cause the external to crash? seeing as an external hard drive is the same thing as a regular internal hard drive...the only thing that makes it external is the case. external hard drives are just as reliable as internals, although i have seen a few external hard drive enclosures go bad, but the disk is still fine. For the most part speed of the drive is going to rely on the buffer and the rpm , most drives will run at 7200rpm and most bigger drives have a 16mb buffer.. aslong as your using USB 2.0 it will be plenty fast, firewire would be even better...
Too Much Stuff to list .
i bought a 29.99 external sata /usb compatible case for my internal 750gb sata, it works great and i can run it from usb 2.0 or through a pci sata port.
