box also has a lot to do with it too. I have a DD 9515 on like 1200WRMS (getitng a new amp soon hopefully), and I can feel my hair moving a bit while driving, not like lifting up or anything but enough that I can feel it on my ears and neck.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
the brz1200.1d can play at .5 ohms? what? i have a hfi1000.1d and it can barely play 1000 watts at 1 ohm. Hifonics amps are overrated to hell, sorry man. I have the 1000.1d again, and its giving me 570 rms at 2 ohms, and possible 700 at 1 ohm. lol... I would check to see if you can turn the gain all the way up on the amp with zero clipping, if you can, you will know that this amp is nothing but overrated :(
I imagine if you had enough Xmax, power, and series tuned 6th order tuned with a very narrow passband, in the right car, you should be able to pull it off.
But even if you did, it'd probably sound like shit.
2007 Pacifica
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I don't understand how you pull off the numbers you do Ric. :D
and Tarball that's impressive on 1 15 even in an xcab. How much power?
2007 Pacifica
Not mine just something i stumbled on and I like it. I think he had 3kw ish on it though.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
One 12" non-sealed off on 4k balls out in a 92 Celica. Hairtrick with a 15"? Very possible especially in such a small car, but it needs to be a very stout 15" that can handle some power. Lower Fs the better, and send it some serious power. Certainly way more than your little Hifonics can deliver. More like 3500W and up minimum. The lower you tune it the more violent/obvious the hairtrick will be but you have to make up for the lower tuning with power. Can't skip on power when using minimal cone area, and definitely need to seal off the trunk from the cabin if you can (unless its a hatch). I don't think you have the equipment for what you want to accomplish.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
well i'm reconing the one I have now, and getting another bl 15, a sundown saz4500(Hopefully), some xspower batts, h/o alt, many other things. actually thinking about walling it off.. not sure yet though.
Sub - 1 Fi BL 15 Dual 1 running at .5 ohms - rebuilding - going to 2 in a 15+ cubic foot box.
Amp - Soundstream TX1.1300d
Mids - Orion Cobalt 6.5s
Tweets - Orion XTRPRO 1"
Wiring - 1/0 stinger ofc
HeadUnit - Pioneer AVH-P1400
Big 3 upgrade
Powercell - Soundquest SBQ2000
My Build!
  • Who's Online   0 Members, 0 Anonymous, 1736 Guests (See full list)
