MrSkippyJ Posted October 21, 2012 Report Posted October 21, 2012 Ok cool. What kind of terminals are you using? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
alaskanzx5 Posted October 21, 2012 Report Posted October 21, 2012 How did you jump the RCA cables? Main RCA's come from HU to first amp then 2 foot set of RCA's go from 1st amps output to second amps intput rca. Not the strapping one. @ alaskanzx5, Ok, thats something i could try, I can;t really disconnect my batteries as there are 3 of them in paralell with a ton of grounds and seperate bus bars so its not worth the hassle. Will that spark hurt anything? disconnect the wire from that goes to the battery from the fuse holder. the spark wont realy hurt anything just more of a safety thing. connect every wire that is on the working amp to the non working amp and see if that fixes it. if it does its the wiring going to the non working amp. if it doesnt its the amp. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 Ok cool. What kind of terminals are you using? Huh? They are Knu Krystal RCA's My 2005 s10 blazer build. 4 zcon 18's walled.
MrSkippyJ Posted October 21, 2012 Report Posted October 21, 2012 Sorry, how are connecting the amp to your sub? How did you get the wire through your box? Drill holes, bolt terminals, terminal cup or what? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 Sorry, how are connecting the amp to your sub? How did you get the wire through your box? Drill holes, bolt terminals, terminal cup or what? Ohh, my bad. Drilled holes in the box. I also heat shrinked the wire around the woofers terminals to stop it from coming loose My 2005 s10 blazer build. 4 zcon 18's walled.
Tarball Posted October 21, 2012 Report Posted October 21, 2012 Question: Have they ever worked properly? http://www.soundsolutionsaudio.com/forum/topic/55681-bc3500s-strapped-wiring-issue/page__p__909540__hl__strap__fromsearch__1#entry909540 I think you may have some wiring issues. Take one amp completely out of the picture and wire both subs to the "bad" amp at 2ohm. Do you still have the cone movement issue? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 Question: Have they ever worked properly? http://www.soundsolu...__1#entry909540 I think you may have some wiring issues. Take one amp completely out of the picture and wire both subs to the "bad" amp at 2ohm. Do you still have the cone movement issue? Yes they are not strapped anymore. Was not ideal. I have them run seperate paralelled to each amp at 1 ohm. Pop tested and checked with dmm, Problem is one amp not putting out. Even swapped amps before and the woofer that worked now would not. My 2005 s10 blazer build. 4 zcon 18's walled.
Tarball Posted October 21, 2012 Report Posted October 21, 2012 Question: Have they ever worked properly? http://www.soundsolu...__1#entry909540 I think you may have some wiring issues. Take one amp completely out of the picture and wire both subs to the "bad" amp at 2ohm. Do you still have the cone movement issue? Yes they are not strapped anymore. Was not ideal. I have them run seperate paralelled to each amp at 1 ohm. Pop tested and checked with dmm, Problem is one amp not putting out. Even swapped amps before and the woofer that worked now would not. When you swapped the amps did you swap everything? Power, ground, RCA, speaker? If yes and still no dice then amp = screwed. If no then try again with swapping the "bad" amp into the "good" amps spot as a complete direct replacement of just that amp to the speaker that the good amp was pushing. use everything known good. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 Question: Have they ever worked properly? http://www.soundsolu...__1#entry909540 I think you may have some wiring issues. Take one amp completely out of the picture and wire both subs to the "bad" amp at 2ohm. Do you still have the cone movement issue? Yes they are not strapped anymore. Was not ideal. I have them run seperate paralelled to each amp at 1 ohm. Pop tested and checked with dmm, Problem is one amp not putting out. Even swapped amps before and the woofer that worked now would not. When you swapped the amps did you swap everything? Power, ground, RCA, speaker? If yes and still no dice then amp = screwed. If no then try again with swapping the "bad" amp into the "good" amps spot as a complete direct replacement of just that amp to the speaker that the good amp was pushing. use everything known good. No, I dont think i swapped power/ground witch i think is the problem hopefully as I don't want to spend $$$ on anthother amp. I mean if the tech said the amp is fine then hopefully i can figure this out. My 2005 s10 blazer build. 4 zcon 18's walled.
