The Saturn: 3 15's, AQ20 tons of fiberglass (Death-Horn) and low-lowz
this id a build!!
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
Thanks, guys :)
Anyways, a bit more...started layering up along the edges with heavy mat.
More later...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Doubtful, the horn below the rear-half of the roof is also supporting it which is on the top of the enclosure, which is connected to the bottom of the car, so things are supported elsewhere too.
And yes, it's some thick ish :)
Team Tupperware
Moar...
More when it happens...
Team Tupperware
WOW!!!!
What are you going to do with the roof? Body filler and bed liner?
Thanks, guys. And the plan is to build it up as close to the factory height+shape as possible and then start filling and sanding from there then probably throw on some black paint and some clearcoat...the green on it is pretty dark and it wont be too noticeably just passing by it.
Team Tupperware
