Need some advice F150 Build. [Sundown][DD]
anythiNG
It will be a few weeks until I install it, but I will for sure post pics of everything when the time comes. Trying to make it really nice and clean, so hopefully it will look nice after I get done.
99 F150
L 50''
H 23''
Top Depth 5''
Bottom Depth 9''
I measured the dims a few days ago. I am not home at the moment so I had to take it from memory, but im pretty sure its right. And with a box that big, at max dimentions, It will effect my leg room a bit, so in the end I would like to get by with a bit smaller of a box than max size depth wise so i ca have leg room.
The mounting depth of the 3512 is 7.38" so likely the motor is going to hit the back wall with the dims above.
99 F150
L 50''
H 23''
Top Depth 5''
Bottom Depth 9''
Yeah, I just realized that earlier. I think I might be able to get a bit deeper on th bottom. Maybe 10.5.
You are most likely going to be limited to a pair of 8s or 10s because of mounting depth. I would personally go with a nice pair of 8s. They will require less airspace and allow you to retain your leg room and will still get loud in a single cab.
What kind of 8's would you recommend? Maybe SA8s or DD 1508s.
Also, if I wanted to run 2 SA8's, I should be able to put 1500w tothem, right?
yes
and if you do the 12, 37-40 is what i do. up to you though. never liked mine at 36
yes
And if I want to do 8's, what kind of box size and tuning should I aim for?
.5-.75 a piece, mid 30s. 34-36hz.
Sundown recommends that exact box size @ 35hz tuning on their site.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Thanks. Just wasnt sure if they would slam full potential in that size. But I guess so.
  • Who's Online   0 Members, 0 Anonymous, 820 Guests (See full list)
