Upgraded but no noticeable difference...
I redid the wires and it made a pretty big difference I can only imagine whatd it sound like with the right box but this morning i was playing it and it blew my fuse after about 2 minutes of playing. It was a 60a fuse is this too small?
That is WAY too small! You should be using a 200 amp fuse for that. What size wire are you running? Only fuse it at 200 if you're wiring can handle that much amperage.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
I have a 200a fuse about 6 inches before the amp its 4ga wire but i should have a 200a fuse right after the battery also instead of a 60a? Also planning on getting 0ga wire soon
I believe 4 gauge is capable of handling 150 amps. So I'd throw a 150 amp fuse on there, but you may still blow the fuse until you can get the 0 gauge on there with a 200 amp fuse.
136.4 Sealed @ 29hz
If you ever decide to do a blowthough stick with 12's for the s10. I'm doing 15s and its just not a best fit. 12s would be simpler to design.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I did the maths for the impedance, and thought I was wrong because nobody noticed the "mistake".
Thank you Alpine !!! I'm more confident with my skills, now !!!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
your welcome now go vote for me in sotm lol
Ok Boss, I'll take a look and probably will vote for you, as I don't want to look at all the nominees !!!
Tread lightly with these reccomendations. If you honestly don't know what you're telling people, don't misguide them.
First thing is first:
http://en.wikipedia....ican_wire_gauge
Ampacity of 4 gauge wire at 140*F/167*F/194*F = 70AMPS/ 85AMPS/ 95AMPS
This means if you're pulling a consistant 95 Amps through true 4AWG oxygen free copper wire, that wire is going to heat up to almost 200*F.
You reccomend that he fuses his '4 gauge' wire at 150 amps. Not a good reccomendation for a safe daily system. 80-100 amps would be fine in most circumstances.
In the audio industry, these are the tolerances companies come up with for wiring gauges.
So who's to say that the 4 gauge he's running isn't actually 6 or 8 gauge? Copper clad ALUMINUM 8 gauge marked as 4 gauge wire?
Ryan.... This being said. What type of wire are you running? Let us give you a safer reccomendation on what your wire can be fused at. Car-B-Ques aren't fun... We can keep you from making one if you're willing to learn the correct way of doing things.
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
