Does shielding in RCA's do anything?
I like KNU's the best. They grip super tight too
I don't see a benefit to super tight RCA's unless there is extreme bass or rattling or the amps move a lot.
I have never used anything other than Walmart stuff. I have never had RCA induced noise. At least, no noticeable noise :)
Well I think it has to do with the power wires touching or being near the RCA/s
2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz
guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
My power wires are ran about 1" from my 3 sets of rcas and I have 0 noise.
It probably has more to do with grounds than anything else.
When I had a bad ground in my other jeep I got whine from the stock alt as well as poor sq
150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
Well a lot of the power lines are touching the rcas. But i do have a pretty bad ground for the mids n highs amp.
Would it be worth running a line back to the battery?
Any way to test the grounding of parts in the car with a dmm?
I ordered the xcorpion quad shilelded rca's from sonics ebay and will post back with results.
I have been sick so i couldnt re-route any wires or anything.
I have seen countless expensive RCAs break not hold up or w.e yet I have like 7 year old Wal-Mart ones that sat in a old garage in the mud and rain you name it. That work 100% if I ever needed em. But for the $$$ I use knu conceptz. The middle pair like $8 are nice. The cheapest one like 5 bucks is a steal for the leg.th you get, but I have pulled an RCA straight out of the plastic molding before.. you get what you pay for TO A POINT with RCAs. Where it become more about asthetics and less about function imo. I'll never pay like 60 bucks for some RCAs lmao f that.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
ground every amp alt and battery to the frame it will give you a greater decrease in resistance then a ground ran from front to back. it cant hurt to do that but the cost to do that compared to grounding everything to the frame rather then buy a whole wire is a better starting point. unless you have an old car/truck that is all rusted out.
look at the ce electronics section on this forum they have some great info on grounding.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No mean to thread jack, but I have a similar question. When running the door speaker wire, can it be ran next to the rcas or should I stay away from them as well?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
door speaker wires wont have much of any power going through them as compare to power wires for you amps. they should be fine.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thanks, that's what I was assuming but wanted to make sure. Would running speaker wire next to power wire cause any problems?
dont think so should be fine.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
