2002 Jaguar X type. 2 12 inch D.A.D KMH Series sealed off trunk.
I couldn't upload straight to Smd so just click the link below to view the gallery
http://imgur.com/a/tatQ4
Box is 3.5 cubes tuned to 35 hz
It was just pieced together to get and idea. the box still needs to be fiber glassed and needs bondo. i know it seems like theres gaps bit its completely sealed from the inside. i just had a bad blade.
2002 X type Jaguar
Two 12 inch DAD KMH Series wired down to 1 ohm
4ft^3 tuned @ 35hz
One Skar Audio Sk 800.1
Pls fix your images. :-(
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
i know i had trouble uploading them so i just used imgur to create an album i hope its not a problem for people
2002 X type Jaguar
4ft^3 tuned @ 35hz
you have some serious gaps in all your seams. id expect major air leaks.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
its all sealed from the inside and its not even close to finished. still have to fiberglass and bondo.
2002 X type Jaguar
4ft^3 tuned @ 35hz
Make sure to seal off the reardeck as well, there's lots of air leaks that can escape from there.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
looking good so far. if you were more careful with cuts and construction you dont even need to use caulk. keep it up. lets see more!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Nice car, nice idea. But, like N8 said, you have some major air leak issue.
thnaks and
its completely sealed from the inside and yeah its not even close to being finished i still have to fiberglass and bondo and it will fix whatever leaks i have
2002 X type Jaguar
4ft^3 tuned @ 35hz
