StoneCold455 Posted November 28, 2012 Report Posted November 28, 2012 How do I know exactly wat hz the filter is set to? mine has a min of 15hz and a max of 35hz.
Jessica Posted November 28, 2012 Report Posted November 28, 2012 How do I know exactly wat hz the filter is set to? mine has a min of 15hz and a max of 35hz. I use a DMM if you don't have a CC-1 . Play a tone at the freq you want to set at, and at a moderate volume, without te subs hooked up. Adjust the SSF till you start to see a voltage drop. It won't be quite as accurate as a CC-1 but it will be pretty close. Same goes for LPF and HPF. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
soundstream15 Posted November 28, 2012 Report Posted November 28, 2012 i was always told 5hz below box tuning
Jessica Posted November 28, 2012 Report Posted November 28, 2012 I wish i had more disposable income. I would test the half octave rule with subs like the skar 12's that ave an fs of 29hz. So I would build a box, tune to like 40 and see how it responds as I get closer to the fs of the sub. Then try a sub with an fs of like 40hhz and see how it responds to a box tuned way lower than the fs. I would like to try tons of combinations of things like that to see what happens. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
BassMunky Posted November 28, 2012 Report Posted November 28, 2012 i rhouhgt it was the hz you want at times the volts or maybe 13.6 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
SnowDrifter Posted November 28, 2012 Report Posted November 28, 2012 How do I know exactly wat hz the filter is set to? mine has a min of 15hz and a max of 35hz. I use a DMM if you don't have a CC-1 . Play a tone at the freq you want to set at, and at a moderate volume, without te subs hooked up. Adjust the SSF till you start to see a voltage drop. It won't be quite as accurate as a CC-1 but it will be pretty close. Same goes for LPF and HPF. Turn your SSF all the way down, play the tone where you want to set your filter at (say 28hz, for example) measure the voltage with a DMM, multiply that number by 0.70710678118654752440084436210485(or however accurate you choose. .707 is a good number) then adjust your filter until the output voltage at that frequency matches your calculated voltage ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Sutliff Posted November 28, 2012 Report Posted November 28, 2012 What about in Infinite Baffle? Two Fi IB312's on an AQ 750.1. Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
bighossf150 Posted June 8, 2013 Report Posted June 8, 2013 Meh. I have my ssf turned all the way down Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
jpsaudio Posted June 8, 2013 Report Posted June 8, 2013 i havent seen a thread discussing this tuning yet..so good iiisssh bro helped out to much
