How important is this wire? I did the big 3 but still gotta run 1/0g from alt to battery. My volts drop to 13.8 lowest while driving. The alt is gonna be a pain to get to so if its not a big deal and not gonna do much do I have to run the alt to battery? I do have an extra battery in the back as well
that is the main power wire. without upgrading the power wire it is almost pointless to do the big 3.
question? where did you ground the alt and the battery? what about your amps?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
basically, all the power from your alt travels through that wire. so yes, its very important. just like the rest of the big 3.
That's all I needed man. Simple short answer
I thought it was but wanted to make sure.
Thanks
