Question about alternator
OK I have a 2003 Mitsubishi Lancer OZ Rally and it has a crappy 90amp alternator now this is the first car/truck I've owned where my system can dim the headlights etc I never had a small output alt I guess BUT I just ordered a 180amp alternator and while I know it will be enough to power my 1000watt amp I'm just curious if there is a way to find out the maximum wattage amp I could get from this alternator (round about). Any help formulas, videos etc is great I'd just like to know so if I buy a upgraded system I can know what to look for thanks!
Difficult to say, you can do higher wattage if you do some extrabatt´s, it´s a math with to much variables, to give a correct answer. In the moment you´l be very fine
with your alt and your 1 K-watt.
Another side of the math is the amp can do XXXX watt´s put, but how many did he realy put out on XXXX music, is not to say.
"in the abundance of water, the fool is thirsty" Bob Marley
Well I'm sorry I wasn't more specific.. I have a Optima yellow top, Big 3 (4g) gonna go 0g when I get the alternator in which will be 180amp.. I have a Stinger voltage gauge going to my amp right now and am going to add one to my battery when I get the alternator also which should be here Tuesday/Wednesday and in by Friday at the latest.. I know I had saw a video on YouTube about a formula but I can't find the video.. Thanks
Thanks I found the video I was talking about and he said 1700watts should use about 150amps as a ie so that gives me a idea right now I'm running a Kenwood 1000 watt amp but it's like 500rms being I have a 90amp alternator and it's using probably 70ish amps (lights, heat/ac etc) that gives me 110amps to play with I was just curious I want to get a L7 or something like that in time because right now I'm running 2 MTX terminators which isn't bad for a cheaper setup but I ideally want that setting off car alarms as I pass sound heh
Don't forget not all amps are as effeceint as others. What one puts out with the use of 150amps 1 amp might put out 1000 Watts and the another might put out 1200.
So a 180amp alt with an amp pulling 150 amps only leaves 30 amps for the car to run off of. Add more draw to that and you could start seeing some good voltage drops if you don't have a good battery bank. Your big 3 needs to be done right to or else you wont be using the alt to its fullest potential. Ground all amps batteries and the alt to the frame.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
This has been moved to the electrical section of the forum.
Please post topics in the appropriate areas...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Sorry..
And it was just a reference I'm not gonna run 1700watts.. and I have the big 3 done properly and the amp grounded to the frame but the big 3 is 4 gauge which I will be changing once I put the alternator in I already have the alt positive wire with inline fuse 0g.. just need to get the block and negative which is simple.
did they include the dropping of efficiency as you lower the resistance cause that 80% is now a lot lower
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
  • Who's Online   0 Members, 0 Anonymous, 672 Guests (See full list)
