depends WHERE its cit, MOST cabs have what is almost like a hollow channel under the window that adds strength dont cut that out.. lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I had to cut part of that out because of the body drop. My bed floor has been raised 5 inches so i had to cut maybe 1.5 of that out. Honestly i feel like ive lost no structural integrity. My blow through cut is extremely small compared to a lot though.
Thats a small cut. Mine was 12x48 :D
I am planning on cutting 12x40. and having a buddy weld in some support if bolting a in a 2x4 doesn't fit my design
My cut through only made my truck stronger ... With the installation of the enclosure.
The trick is to prevent water leaks ... That's why you have to make precision cuts.
So the acordian boot will fit correctly.
So do you recommend cutting it with a sawsall or an air saw? Is it easier to unbolt the bed and slide it back to make room while making the cut?
I did mine with a sawzall. I cut both the bed and cab at the same time so it was even.
I tried that and ended up ruining my sawzall blade. I just measure a couple times and drilled a straight hole through all four corners and went straight through the bed and cab. That way I knew where the corners were when I got in the cab to cut. I used a combo of electric and air grinder with cutting blades. I've also seen people use jig saws, but that seems like a pain. If you are that concerned with strength and integrity learn to weld and weld some braces in. Honestly I think you only need to be concerned if you are doing a full walk through or something. My truck has a been body dropped and the frame has been cut up. Sure it had caused some issues, but I'm getting them worked out. So far the integrity of the cab and bed is still there. Even though its all thin ass sheet metal.
I cut both at the same time with a airsaw (similar to a sawzall) with a short blade ...
Took a while, but I was in no hurry ...
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
