hi i was wondering what should i do...i currently have a Premier 12" Champion Series PRO Subwoofers D4 version
TS-W3001D4: Dual 4 ohm, 4 Layer, Long Coil (2 ohm x or 8 ohm).
i recently got a kenwod amp a POS it smells like its on fire constantly. i read up on it and know its very unstable at 2 ohms and 1 ohm.
http://www.pioneerelectronics.ca/POCEN/Pro...01D2%7CD4?tab=B
i was wonder what amp i should use. i was wondering if hifonics were good, if so hows this amp
HIFONICS BRUTUS BXi2006D 2000W Mono Car Amplifier/Amp
Type: Mono Block
1-Ohm Power Rating 1x2000
4-Ohm Power Rating 1x650
2-Ohm Power Rating 1x1300
Turn-On Delay/ Mute
Frequency Response @-3dB: 20-250Hz
Damping Factor: >250
Signal To Noise Ratio: > 95 dB
THD + Noise: < 0.1%
Variable Input Level Control (RCA/Unbalanced): 0.2V - 9V
Variable Input Level Control (Mini DIN Balanced): 0.4V - 18V
Input Impedance: 47k Ohm
Input Impedance: 20k Ohm
Power and Specific Diagnostics LEDs
Protection DC, Short Circuit, Overload
Power Supply - All MOSFET: Full PWM
Power Output Circuit Type: Ultra-Fi MOSFET
Variable Phase Shift
Phase Change in Degrees: 0-+180
Variable Low-Pass 24 dB Octave: 35Hz - 250Hz
Variable Subsonic Filter: 15Hz - 35Hz
Bass EQ: 0-+18 dB
Balanced Inputs
RCA Inputs
RCA Line Outputs
Remote Bass Module Included (Via RJ11 Jack)
Gold Plated Power Terminal Blocks: 2 GA
Gold Plated Speaker Terminal Blocks: 8 GA
Dimensions WxHxL: 16.50x2.63x10.39
1 Year Manufacturer Warranty
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
Type: Mono Block
Turn-On Delay/ Mute
THD + Noise: < 0.1%
Bass EQ: 0-+18 dB
Balanced Inputs
RCA Inputs
RCA Line Outputs
personally, I love hifonics, but Ive heard from many that they are overrated. So dont expect to be puttin out 2 thou.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
the bxi2006d is a great budget amp (which is why alot of people run them). Although your not going to see rated power from it, it will do a great job powering that pioneer sub, i used to have the older version of it a while back. Ive installed a a bxi2006d in a friends navigator that treats his stuff like total crap and it is still working fine after all this time. What smells like its constantly burning, the amp or the sub? i wouldnt be surprised if your amp is going into some serious clipping and causing your sub to overheat. So set your gains properly, start with a DMM.
Too Much Stuff to list .
thanks for all your help and a quick question if im thinking of spending $300 on a new amp any recommendation?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
Type: Mono Block
Turn-On Delay/ Mute
THD + Noise: < 0.1%
Bass EQ: 0-+18 dB
Balanced Inputs
RCA Inputs
RCA Line Outputs
I personally like their amps that's all I have n my car currently I don't think it wud be a bad choice for u
4 I.A. Warden 15s
8 I.A. 20.1s
2010 140.0-149.9 Bass Race Points Champ/Over all champ
2010 140.0-149.9 Bass Race S.C. Regional Champ
2010 FL Regional Middle Weight Champ
2010 INAC Middle Weight Bass Boxing Champ
i have the older hifonics 1500ds and hell i love them. i'm only playing each of mine at 2 ohm toward my RF T2 12s and hell they bang hard as hell. i've heard the newer hifonics amps do more near rated output versus the older ones.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Which ones are the newer ones?
http://www.sonicelectronix.com/viewcat.php...&new_page=1
as far as hifonics goes anything ending in 06 or 07 are the newer ones. i had the 1500d (year 2000 model).
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
