Skar VVX-12 D4 Bass Box Pro box help
89capricebass
Alright so I just ordered a VVX-12 D4 and it'll be here on thursday. So I figured I would try and design a box for it using bass box pro 6. here is a screen shot of what I have so far
Is this any good? I Dont really know what I'm doing with this program. Should I just stick with torres?
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
It all comes down to music taste an the outcome you wish to active.
So right to me may not be to you
Post some more info
Car
Amp
Planed wire config with d4
Max measurement wall to wall
Measurements you wish stay within
Music you lesion to
And what u want to achive sq, spl
If u can work Bass Box Pro 6, then go for it, I never could figure it out so I stick with Torres and good ol trial and error.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
yea what are you getting amp wise? and music?
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
Post some more info
Car
Amp
Music you lesion to
The Car is a 2000 ford focus sedan. Box will be in the trunk.
Amp will be a Hifonics Brutus BRZ1700.1D. Sub will be wired at 2 ohms until I can get a second vvx and then I'll wire to 1 ohm.
Max measurements I can go are 30" wide x 20 deep x 16 tall.
90% of my music is decaf the rest is regular rap and some rock/metal. I just want a loud box that gets nasty on the lows but isnt a one note wonder.
Here Is what I get in torres and it looks good to me
Front Highs: stock
Back Mids: Stock
this is my box ill be running 2 Hifonics Brutus BRZ1700.1D and 2 skar vvx 12's and this my box http://www.stevemeadedesigns.com/board/topic/157230-custom-made-box-for-2-skar-audio-vvx-12/ i recommend to make the port size a little bigger than mine.
2010 Mazda 3
*Rebuild Time*
this is my box ill be running 2 Hifonics Brutus BRZ1700.1D and 2 skar vvx 12's and this my box http://www.stevemead...r-audio-vvx-12/ i recommend to make the port size a little bigger than mine.
Port area or port area per foot?
Front Highs: stock
Back Mids: Stock
Well this is the port area on my box 2.75 ft^3 this is what is recommended for 2 12 3.5 ft^3 and 14 - 16 ft^3 per cube
2010 Mazda 3
*Rebuild Time*
I will only have 1 sub for this box. Won't have the 2nd for a couple of months and when I get it I'll build a different box. This box is only for 1 sub.
Front Highs: stock
Back Mids: Stock
Just as a reference, here is a suggestion:
Enclosure Specifications:
Fb = 32 Hz
Vb = 1.78 ft^3
External Height = 14 in
External Width = 22.5 in
External Depth = 18 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 19 3/4 x 12 1/2
Back = 22 1/2 x 12 1/2
Left & Right Sides:
Side 1 = 16 1/2 x 12 1/2
Side 2 = 17 1/4 x 12 1/2
Top & Bottom = 22 1/2 x 18
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 12 1/2
Extension = 13 1/2 x 12 1/2
Assembly guide (generic dimensions):
Your BBP6 amplitude response looks atypical, you may want to check the sub parameters.
  • Who's Online   0 Members, 0 Anonymous, 1151 Guests (See full list)
