Kyblack76 Posted December 14, 2012 Report Share Posted December 14, 2012 (edited) Thats better help..... thank you guys... really..... we are all where were at.....funds wise, and for some, it isnt changin really quick....... So, thank you. EDIT - and a 0db tune for what? your subs? that would be even MORE conservative.. Edited December 14, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
moh.vze.com Posted December 14, 2012 Author Report Share Posted December 14, 2012 (edited) Another side note: I'm not going to try and use the whole 5K watts from the amp because I only plan on powering 2200W to each sub. So when I go to tune with the amp with the oscope for that square tip, I"m going to lower the gain enough so that I know that clip is gone for sure and then calculate to see how much power it's actually going to give the sub and lower the gain even more if I need to. I'll wait for one of the DC's suggestion before swapping out that custom SSF mod. Edited December 14, 2012 by moh.vze.com Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
will77530 Posted December 14, 2012 Report Share Posted December 14, 2012 (edited) good luck with your install Edited December 14, 2012 by will77530 Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted December 14, 2012 Report Share Posted December 14, 2012 Using an Oscope is easy to use as a DD-1, I have done both. For ease of use the DD-1 any day of the week, but it is nice to have a visual readout of what is really going on with an Oscope. you want to use the max volume that keeps both the mids/highs amp and bass amp output signals clean. You also want to test the max volume unclipped from the HU. And i would use -5db or roughly that for the sub amp. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Kyblack76 Posted December 14, 2012 Report Share Posted December 14, 2012 I wasn't trying to turn this into a tool vs tool thread. I also have both. Multiples of both in fact. What I was trying to do was help/encourage a member that's dropped a good amount of money on his gear. Unlike some. And atleast knows what he wants. Guess that is harder to do than I thought. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
CJ18 Posted December 14, 2012 Report Share Posted December 14, 2012 I am not a fan of the vellman scope. For me it just wasnt easy to use. I bought a TPI 440 Plus and loved it. I used it up until the DD1 came out. Now I only use it to see what kind of voltage I am seeing at the amp when I am using the DD1 to tune. I have to go with the crowd here and recommend the DD1 and CC1 be used to tune everything. I know you said that you didnt want to buy anymore tools this year, but maybe make them a Christmas present to yourself. Also, just tune the amp with a 0db or -5 db tone and you will be just fine. There is no way to calculate how much power the amp is going to actually put out. That is going to vary based on voltage and impedance rise. Quote Link to comment Share on other sites More sharing options...
moh.vze.com Posted December 14, 2012 Author Report Share Posted December 14, 2012 Also, just tune the amp with a 0db or -5 db tone and you will be just fine. There is no way to calculate how much power the amp is going to actually put out. That is going to vary based on voltage and impedance rise. Can't I just clamp test it and calculate to see how much power the amp is outputting? I just spent $100 on that clamp tester Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
CJ18 Posted December 14, 2012 Report Share Posted December 14, 2012 Yes you can, but that has to be done with the subs hooked up. You cant clamp and amp unloaded. Quote Link to comment Share on other sites More sharing options...
will77530 Posted December 14, 2012 Report Share Posted December 14, 2012 that has also been proven to not be accurate it will give you a good idea though Quote Link to comment Share on other sites More sharing options...
will77530 Posted December 14, 2012 Report Share Posted December 14, 2012 where are you at you can use my dd-1 Quote Link to comment Share on other sites More sharing options...
