DC Sound Lab
Do I get something if I let you guys know that the "10k" amp like leads to "12k" amp specs? Haha
And is there specs for the 10k anywhere?
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
The 10.0kw competition series amplifier is a 10,000 watt mono block. It is built for 12 volt audio systems.
It will not operate on 16 or 18 volt systems. It is a linkable amp and designed to run at 1 ohm per amp or 2 ohms when strapped for 20,000 watts of power. It comes with a bass knob and a clipping indicator.
For power inputs it will accept triple 0 awg for power and triple 0 awg for ground.
Key Features
• 1 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• Triple 0 awg power and ground inputs
We recommend for installation
• 1 upgraded battery under the hood
• 3 extra 800ci battery in the rear
• Minimum of two 0 awg ran from the front battery to the rear batterys
• All 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 6 runs into the amp
• 2 upgraded aftermarket alternators
• Dash mounted voltage meter
Features Voltage 10.0kw Output Power (RMS) 4 ohm 14.4V 3,000W x 1 2 ohm 5,500W x 1 1 ohm 10,000W x 1 1 ohm 16V N/A 1 ohm 18V N/A Input Sensitivity 6V~0.2V Low Pass Filter Switchable ( @ 24 dB Slope) Variable Hz 35~250 Subsonic Filter Switchable ( @ 24dB slope ) Variable Hz 10~50 Bass Boost Variable dB 0-9dB Frequency Response Hz 15-270 Signal to Noise Ratio dB 100 Damping factor 150< Efficiency @ 4ohm % Over 90% THD @ 4ohms Less than 0.1% Fuse Rating 1,000 Amps Linked Fuse Rating 2,000 Amps Indicator Power Yes Protection Yes Clip Yes Speaker & Power terminal Mold Type Yes Power Gauge 0Ga x 3 Heatsink Length 37 Heatsink Width inch/mm 11.5 Heatsink Height 2.6
How does the 10k compare to the 9k on lower voltage (under 14v)?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Nice pictures. :takepix:
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
