Multiple batteries, what if one dies
So lets say I have 3 batteries in back and 1 in front. Other than demo's or something causing some serious voltage drop, how would I know a battery died and which one it is?
your resting voltage will be lower and you will drop faster.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If one is bad or dead, you would see lower voltage all the time, that dead battery will pull down the other batteries trying to charge itself until the point it is completely dead then you would only notice a different when the system is on and up to normal demo volume. To check you would need to have each battery load tested with a battery load tester or do it yourself. To do it yourself just disconnect each battery, charge up to 13.1 or greater, then put some kind of load on it, light, anything, remove the load and see if voltage recovers. if is doesn't go back up then battery no good, generally speaking you would need to apply a pretty big load to it to get some good dip, like 1 volt or more and then you can see if it will recover. Normally what I do is replace my starting battery with said bad battery in question, the starter will put a nice load on it lol.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Thanks for the info. learn something new here all the time
  • Who's Online   0 Members, 0 Anonymous, 799 Guests (See full list)
