Diagnose This Blown AQ 3500? [Pics]
8MileRoad
Im on mobile but your voltage may be the culprit here. Charging way high
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Looks like you toasted some of the MOSFETs from the pic. I can't tell all the damage done from the pics but too much input voltage or a weird spike of voltage could cause something like this.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
AQ 3500 Powering 4 IA 18's
2 16 volt xs power battery's
excessive amperage Alt externally regulated. charging between 18-19
For one, those hand rails shouldn't be touching each other. Now, the question is did time,heat,vibration, cause those bars to touch causing the failure? Or was the root cause something else causing the failure? Or a combination of above and or plus some?
The amp was previously mine and those rails weren't touching. I'm with Nate. It shouldn't have seen 19 volts.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
  • Who's Online   0 Members, 0 Anonymous, 1331 Guests (See full list)
