naenae Posted January 17, 2013 Report Posted January 17, 2013 Ported 0.5-0.75 ft^3 @ 35hz Displacement 0.08 ft^3 Depth 6 5/8" Outside Diameter 8 3/8" Cut-Out 7 3/8" Or at least explain this to a noob.
Kyblack76 Posted January 17, 2013 Report Posted January 17, 2013 8 " Sub specs ?? The recomended vol and tuning What the driver takes up in space Depth into the enclosure the driver will land over all diameter of driver - looks like a 8" The hole youll cut, for the driver to fit Cool? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bcpballer64 Posted January 17, 2013 Report Posted January 17, 2013 Ported 0.5-0.75 ft^3 @ 35hz Displacement 0.08 ft^3 Depth 6 5/8" Outside Diameter 8 3/8" Cut-Out 7 3/8" Or at least explain this to a noob. Ported 0.5-0.75 ft^3 @ 35hz = Recommended box size Displacement 0.08 ft^3 = How much air the sub takes up Depth 6 5/8" = Overall depth of the sub (how far into the box it goes) Outside Diameter 8 3/8" = Overall width of the sub through the widest point Cut-Out 7 3/8" = How big the hole needs to be Or at least explain this to a noob. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
naenae Posted January 17, 2013 Author Report Posted January 17, 2013 8 " Sub specs ?? The recomended vol and tuning What the driver takes up in space Depth into the enclosure the driver will land over all diameter of driver - looks like a 8" The hole youll cut, for the driver to fit Cool? Yes thanks
naenae Posted January 17, 2013 Author Report Posted January 17, 2013 Ported 0.5-0.75 ft^3 @ 35hz Displacement 0.08 ft^3 Depth 6 5/8" Outside Diameter 8 3/8" Cut-Out 7 3/8" Or at least explain this to a noob. Ported 0.5-0.75 ft^3 @ 35hz = Recommended box size Displacement 0.08 ft^3 = How much air the sub takes up Depth 6 5/8" = Overall depth of the sub (how far into the box it goes) Outside Diameter 8 3/8" = Overall width of the sub through the widest point Cut-Out 7 3/8" = How big the hole needs to be Or at least explain this to a noob. Thanks :3
Tarball Posted January 17, 2013 Report Posted January 17, 2013 Looks to be an 8 inch subwoofer that has a rcommended enclosur eof .5-.75 cubic feet with a tuning of 35hz. It is 6 5/8" measured from the magnet to the part of the frame that mounts to the box. The subwoofer itself displaces .08 cubic feet of space, so you want ot increase your enclosure size by this much for traditional mounting (non-inverted). The hole that you cut should be a circle that has a diameter of 7 3/8" . Pretty stragiht forward. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
lifes a BOX Posted January 17, 2013 Report Posted January 17, 2013 That "ported" is the box size recommendation for a ported box The port should be tuned at 35hz Displacement is how much room the sub takes in the box Depth is how long the sub is in the box Outside diameter is the size of the sub with the outer ring Cut out is the size of the hole you should cut for fitting in a box
CleanSierra Posted January 17, 2013 Report Posted January 17, 2013 It's a Sundown SA8 V.2 right? What do I get for winning?!?!? Im not the one you want to try to troll. Just a fyi for you.
Hotdog Posted January 17, 2013 Report Posted January 17, 2013 And dont forget to subtract the displacement of the port. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
