Just have a question about the wiring of the Skar 4500.1D. I know that it has 2 sets of power and ground inputs but does that mean that I have to fuse both power wires going into the amplifier? I'm just wondering so that I don't do something wrong. I also noticed that the Skar 4500.1D takes a 450 amp fuse. I don't know where to find a fuse rated at 450 for my power wire. I don't feel like getting a 250 or 300 amp rated fuse and end up blowing the fuse. Or would I be okay with a 250 or 300 I don't think that I would be okay with that.
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
Sounds good thank you for the reply. :)
DEH80-PRS
XS Power d3400
  • 3 weeks later...
I'm actually using 1/0 gauge CCA wire from audiotechix, Should I still fuse with a 300A Fuse or should I go with a 250A Fuse, I don't want to blow the fuses or damage the Amplifier. I am getting a 250A Alternator from Singer.
DEH80-PRS
XS Power d3400
You'll be fine with either a 250 or 300 amp fuse on each power input. As long as your fuses equal or surpass the amp's fuse rating, you're set.
1993 Suburban
6 Crossfire XT3 15s
Crossfire XS-16k
Crossfire mids & highs and amps
65ah Cmax bank
Iraggi 320a and Mechman 300a
Even though I'm using CCA and not OFC? Would I burn up the wire if I used a 300A fuse?
DEH80-PRS
XS Power d3400
You don't worry about the amp... You fuse for the wire
quote name="Soahctnelis" post="2334759" timestamp="1360218042"]
Cca is usually rated 250ish amps @ 20ft length... If your run is under that you'll be fine
Edit.... Fucked that quote up.. I'm on mobile sorry
Edited by Nate Futuristic
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Define surpass the amps fuse rating. Are you saying larger than the amps required fuse rating is ok???
10501650_10203332501847103_1859383749711
Blown
Whoa, sorry, that was a bit of a mistype. I was trying to say that you should try to equal the amp's fuse rating.
1993 Suburban
6 Crossfire XT3 15s
Crossfire XS-16k
65ah Cmax bank
250 amp for cca, 300 amp for ofc
Used to have a loud truck
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
