Pro Audio Subwoofers In A Car Audio Setup
X2..... ^
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Not to mention if you want to bang out something in the low 30s to mid 20s you will want that sp4.
You guys do know that sensitivity is rated at 1khz, even for subwoofers?
Four of the eminence woofers should get as loud, but at a higher frequency.
They won't give you the lows that car audio subwoofers will give you.
You'd be better off with 2 18 BL's, then those pro audio woofers.
There is a reason why they make home audio, car audio or mobile audio subwoofers/speakers. ;)
Heavy ass coil and a big cone = not sensitive, but the massive magnets and motor force help combat that which is my some massive ground pounding subs can be extremely musical.
ZVX 12 with a bl of over 40.... Motor force for days :)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
actually the SP4 motors arent that strong with a BL^2/Re rating of 144 compared to say the AA mayhems 223 or the FI UFO motors 240...but i agree OP is better off with a REAL subwoofer over a PA woofer.PA woofers have good impact to say about 40hz but roll off fast after that.....
2000 Suburban 6 runs of 2/0
12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door
8 banks of blue Maxwells + 260ah of Yin Long LTOs
2 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
161.6@38hz DBdrag  sealed on the dash… 162.54 outlaw…161.14 Meca headrest
  • Who's Online   0 Members, 0 Anonymous, 1370 Guests (See full list)
