Lunatic Posted January 19, 2013 Report Posted January 19, 2013 i ant to kno if u could strap a cunch 1500.1 monoblock and if it might b stab to at 1 ohm strapped i kkno it will put stain on the amp but if i keep a close eye on it and set th controles right is it possiabe??
Watch the bass Posted January 19, 2013 Report Posted January 19, 2013 I read nothing from strapable http://www.sonicelectronix.com/item_23679_Crunch-PZT1500.1.html "in the abundance of water, the fool is thirsty" Bob Marley
zydrix Posted January 19, 2013 Report Posted January 19, 2013 u might have to gain match those amps if you want to run 2 of them, steave did a video of gain matching to crunch amps. that might help you out My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
wellington Posted January 25, 2013 Report Posted January 25, 2013 Why don't you get an actual 1500w rms amp like my 1500D that is linkable instead of that POS $90 750w rms amp. 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
kbsmoker Posted January 25, 2013 Report Posted January 25, 2013 Why don't you get an actual 1500w rms amp like my 1500D that is linkable instead of that POS $90 750w rms amp. Why bash a $90 amp when you buy $60 subs lol www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator
iwannabeloud Posted January 25, 2013 Report Posted January 25, 2013 Why don't you get an actual 1500w rms amp like my 1500D that is linkable instead of that POS $90 750w rms amp. Why don't you get an actual subwoofer instead of that POS $60 vvme? Edit: You're the self proclaimed "guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club" but you bash other people when they "cheap" equipment. What a freaking hypocrite. I don't put images in my signature to let people know I mean business.
n8ball2013 Posted January 25, 2013 Report Posted January 25, 2013 Why don't you get an actual 1500w rms amp like my 1500D that is linkable instead of that POS $90 750w rms amp. Why don't you get an actual subwoofer instead of that POS $60 vvme? Edit: You're the self proclaimed "guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club" but you bash other people when they "cheap" equipment. What a freaking hypocrite. actually I gave him that title hes a troll ignore him. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Team Maxxsonics John Posted January 25, 2013 Report Posted January 25, 2013 You can strap the amps if you get a strapping module (Maxx-Link). Do not run the amps strapped at 1-Ohm....you will certainly damage them.
SnowDrifter Posted January 25, 2013 Report Posted January 25, 2013 Well... You can strap pretty much any amp. The only difference is whether it "natively" supports it or if you have to get something to handle that externally. But that being said, I wouldn't strap cheapo budget amps at 1 ohm. That's just asking for trouble ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Team Maxxsonics John Posted January 25, 2013 Report Posted January 25, 2013 Well... You can strap pretty much any amp. The only difference is whether it "natively" supports it or if you have to get something to handle that externally. But that being said, I wouldn't strap cheapo budget amps at 1 ohm. That's just asking for trouble Yes, you can strap pretty much strap any mono amps (not multi-channel amps..2, 3, 4.... channel) with a strapping module. I also strongly advise against strapping any set of mono amp rated at 2-Ohms when the factory rates the amps at 1-Ohm stable per amp. If someone tells you it's ok, send an e-mail the manufacturer and ask them. If they say it ok in the body of the e-mail, post it... I would like to see who says that is ok (and of course if they will warranty it if it fails.
