XS Power
D3400 & 320 mechman alt ok for 4K?
Will 3 D3400's and a 320 amp Mechman S series Alternator be enough to run my system with a BC3500? it won't see much comp time but it will be daily.
2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp
RE Audio SEX 12D4 Subs (12")
Hifonics Brutus BRZ1200.1D
NVX 4 gauge wiring
NVX Deadner
XS Power D925
Big 3 1/0 ga Q Power wire
Custom box by Pro Audio Gulfport, MS
137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up
You should be great. Just do the Big 3 upgrade.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
that will be plenty. what is the idle rating on the 320.
the turn on is 500 rpm and starts making good output at 800 rpm and goes to 320 at 1800 rpm. it is right in my range for my car. I'll be using one of the D3400's as a starting battery and the other two will be in the back for the amps.
NVX 4 gauge wiring
NVX Deadner
XS Power D925
:encore:
i can't wait to get this stuff ordered and start watching all the goodie come in. thanks for the help guys.
NVX 4 gauge wiring
NVX Deadner
XS Power D925
  • Who's Online   2 Members, 0 Anonymous, 595 Guests (See full list)
