What are you running on stock alternator?
i ran my hifonics brz 1700.1 at 1 ohm along with my kicker zx350.4 stock alt putting out 95 amps ad i had the big 3 done and a napa battery 1 run of welder cable not sure on the awg but equivalent to 0 gauge. and 4 gauge knuconcepts. voltage dropped like a mother. then i got my H\O alt. lol
  • 6 months later...
94 cadillac fleetwood
big 3 done
xp3000 and d3400
stock 140a alt
q1-3500
full tilt seen it dip to low 11s
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
130A Stock Delco Alt
MMATS M3000.1 on 12" ZCON
MB quart 4.80
Duralast platinum up front
Big 3 done with KNU OFC 1/0
1 run of KNU CCA 1/0
2 XS power d975s in rear
KNU OFC 1/0 filling gaps
I drop to lowest 13.1-13.2 from 14.4 on really punchy or low songs.
Going to buy some welding cable for my run front to back.
Anyone have experience with some 1/0 or 2/0 flexible stuff?
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
  • 3 weeks later...
105 Amp stock alternator
Napa Premium Battery
Single Run KnuKonceptz 0 KCA Cable to KNF-23 Block
4 gauge KCA to the amps
BIG 3 with KnuKonceptz 0 KCA Cable
Grounds ran same
Amps:
Two Rockford Fosgate Prime R250X1's @ 2ohm load rated 250rms at 2ohm
One Rockford Fosgate Prime R250X1 @ 4ohm x 4ch rated 40rms x 4 @ 4ohm
Runs at 14.1 - 14.4 at idle voltage drop to avg 13.5
http://www.stevemeadedesigns.com/board/topic/178713-ekcasa-1993-chevy-c1500-ext-cab/#entry2645541
3bc3a7ec-d90c-40a7-928f-eef8c019b42b_zpswww.facebook.com/EKCASA
System:
All Rockford Fosgate
Front: 2 Pair Prime 6.5's and 1 pair Prime 5.25 Components
Rear: 1 Pair Prime 6.5 3 Ways
Subs: 4 Prime R2D2-12's
Amps:
Front: Prime R250X4
Subs: 2 Prime 500X1d's
HU: JVC KD-AR959BS
2 Optima Yellow Tops
Singer 230A H/O Alt.
Lots of KnuKonceptz 1/0 and accessories
105 Sq ft Kno Knoise deadener
2011 Malibu 2.4l:
140 amp stock alternator
Stock front batt, group 27 I believe...4 Marine deep cell batteries group 31's similiar to DEKA's (each weighs around 60lbs)
Currently running a CT Sounds 7000.1 and a Soundstream Stealth stl 4.500
Big Three has been done
Have 2 runs of 1/0 OFC wire to back. One run to each dual bank of Batteries.
The battery Banks are connected to gether with mutiple runs of 1/0 OFC
From the dual banks there are three runs of 1/0 OFC to the 7000.1 and a 4 gauge run of OFC to the SS amp.
Car running resting voltage runs between 13.8 and 14.5 depending on what the hell the car wants to do
Lowest voltage I have seen so far wide open is 12.5ish...Havent been that high again on amp yet, spider glue failed on one of my Wardens, this has been fixed, but breaking them in more before going all out again :)
You can run almost any amount of wattage on a stock alternator is the battery bank is big enough... Niel Barber, Tommy Mckinnie, etc... usually don't even run their vehicle when they are playing 40,000+ Watts RMS.
The other thing to consider is what kind of vehicle it is. A Honda Civic might have a 65 amp alternator that charges at 13.8 volts, whereas a new Escalade will come stock with a 165 amp alternator that charges in the 14 volt range. Obviously the stock alternator on the Escalade will support over double the power that the Civic will in stock form, so you can't just lump all "stock alternators" into the same category.
The primary difference is the amount of time you can play at high volume levels before voltage drop becomes a problem. Having a high output alternator mainly reduces the amount of battery capacity you have to have, and increases the amount of time you can play the system at high volume before voltage drop becomes a problem. If you don't want to change out the alternator, you can always add more batteries to the bank, and charge the batteries when the vehicle is not in use to help make life easier on the stock alternator.
2000 Jeep Cherokee (XJ) 4.0/4X4
Stock 117a alt externally regulated
Sears Diehard Platinum battery
Big 3 done with 0 gauge on top of factory wiring (except that stupid braided thing, I replaced that)
0 gauge run to amps/grounds
PPI PC21400 (have also used Kicker ZR1000) + Pioneer PRS-D800
13v minimum on music when the regulator is being stupid and resting at 13.5, with test tones it was either 12.3 or 12.5 at idle. Keep in mind I am wired at 4ohm and nothing was turned on except the sound system and headlights.
  • Who's Online   0 Members, 0 Anonymous, 1455 Guests (See full list)
