What are you running on stock alternator?
2000 Ranger (Factory alt is 95amp) Have a factory 135 amp explorer alt installed
Duralast Gold battery up front
Big 3 in ofc 4 awg
4 awg power to an audiopoop AP1500 (older style)
charging at 14.4-14.5v at idle and dropping to 13.8v at the amp wired to 1 ohm full tilt (max dd1 clean volume)
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
Stock 180 amp alt
Big 3
1 positive and 1 negative run of 1/0 OFC to the back
3.5k @ 1ohm
G34 red top up front
Drop to around 12.6 if I really beat on it AROUND TUNING, If i play anything too high I instantly see mid 10v haha
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
90a alternator (scion xb)
Optima Blue top under hood
XS Power 950 in the back
BRZ-2100 @ .5 ohm
Kicker 300.2
Voltage drops to around 11 at 2k rpm/full tilt
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
Stock 180 amp alt
Big 3
3.5k @ 1ohm
what kind of car has a 180 amp stock alt ? Lucky
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
110 Amp stock alt
d1200 (starting)
xp300 near amp
2 runs of 1/0 CCA
AQ 3500 @ 1ohm
Dips to about 13.6 at idle, charges around 14.1 - 14.2
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Jeep Commander stock 160 puts out 14.9. Ohio Generator said that actually putting out 180 at high rpms. Never drops below 14.3.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Stock 140 amp alt.
I ran a Soundstream TX1.2000 for a while before I got my XXX and with the TX1 I dropped from 14.6 to 14.4 while driving and to 14.1 at idle.
was prolly only getting 1200 watts or so out of it at .7 ohms but for $160 it was a nice amp.
I had a kinetic 35ah batt as my second batt and big three. stock batt under the hood. when I put the XXX in it dropped to about 13 but would go right back
up to 14.6 just needed some more batts. also ran the XXX at .7.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
2012 Ford Focus Sedan
Stock 150A (PCM Controlled)
D6500 (Replaced Stock)
No Big 3 (Soon though)
1 Run of 2 AWG
Hifonics 1700.1D
Hifonics 80.4
Charging voltage at 14.4
Dips to about 12.9
2012 Ford Focus Sedan:
Audiopipe, Sundown, Focal, XS Power....
110 Amp stock alt
d1200 (starting)
xp300 near amp
2 runs of 1/0 CCA
AQ 3500 @ 1ohm
So a 110a alternator and 160ah of battery is good for 4300W of power? That seems crazy to me. How long can you run it full tilt and maintain that 13.6?
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
Hifonics brz2100
Kicker 300.2
Optima Blue Top
Build log
110 Amp stock alt
d1200 (starting)
xp300 near amp
2 runs of 1/0 CCA
AQ 3500 @ 1ohm
some people may like to exaggerate. I highly doubt that he has that much drop. Unless his volt meter is wack.
I have either a 120A alt, d925 and d3100 and on 2k I drop to 12.9 at idle, 13.8 at 2k rpm when I'm charging 14.4 hot (at 50 degrees out)
oh well, this was intended to be a reference for people, not to show off. hopefully it doesn't turn into, "Hey! I can run 10k on stock alt and two D3100s and only drop to 13.5!"
  • Who's Online   1 Member, 0 Anonymous, 1185 Guests (See full list)
