need help on a box for l7 15
kidd666
REaudio.com and go the box calculator. This will calculate cut sheets and volume of an L ported box. This is a good start if its your first time building. I would go 3.5-4 cubic ft. sub up port up or sub front port front.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
you're expecting free box designs and you want it fast? you must be joking.
the re box calc has been proven inaccurate. the Torres one on here is much better.
Talk to joe x the specs for your box are already given. Anywhere from 3.5 cubes net and up will work with a tuning around 33-36hz.
Dont give it too much port area as i found from going from 16 inches per port to 12-14 it sounded a bit better sq wise.
Also is your sub a dual 2 or 4 ohm?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
That's the help i wanted. Im sorry for seeming like im expecting a design. I just wanted some opinions and some help as far as the box calculator
My friend has his on 1400 with gains 3/4 and stock electrical. He smelled it for the first week or so cause he had been running it on 900 for the longest time and its still going on 1400, never smell It anymore. Runs like a champ
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
ok so ive been thinking about it all day and im wondering what would be a good tuning frq for the box. i listen to all different kinds of music and i like the lows but i dont want to miss out on the higher notes too much so what should i tune it to?
I was thinking about running it at 1 ohm on 1500 watts or do u think that would be too much?
According to Kicker manual, it appears that S15L7 only 'sees' ~750 watts in any vented box. Personal, I'd just watch the gain control if the amp you have has 1,500 watts or more on it. Use common sense and do not intentionally abuse the subwoofer. As long as everything is under control, I'm sure you'll be happy with it. I've ran a pair of S12L7 and a pair of S10L7 at other time and I loved it. Not a single problem.
