Swordlordboy1234 Posted February 9, 2013 Report Share Posted February 9, 2013 How do you guys go about dealing with weight issues in your cars? My car only has (2) 43 lb subs, a 20-30 lb amp... And (2) 50-60 lb batteries, but the rear end sits really low. I figure before I can attempt a wall I should address the weight handling of my car. 96 accord ex sedan. I'd appreciate any hints on places to look to beef up springs or weight handling. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
OrionStang Posted February 9, 2013 Report Share Posted February 9, 2013 Thats one reason I removed my wall. All 800lbs of it LOL. Look into helper bags. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
kirill007 Posted February 9, 2013 Report Share Posted February 9, 2013 If the rear end drops too low with only 200pounds, then there is something wrong with the springs(/shocks). The car should be able to handle 500-600 pounds easily/safely. Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 9, 2013 Report Share Posted February 9, 2013 Lower the front to match You can get stiffer springs, or spring spacers ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted February 9, 2013 Report Share Posted February 9, 2013 If the rear end drops too low with only 200pounds, then there is something wrong with the springs(/shocks). The car should be able to handle 500-600 pounds easily/safely. This. I thought the same thing with my first system (which couldn't have weighed more than 200 pounds). Pulled the old shocks/springs out, and one was completely blown and the other was a on it'sway. It's a '96, if you'e sitting low with what you have now chances are you're stock suspension is just worn out. I say look into helper bags or all new rear springs. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
hdorre Posted February 10, 2013 Report Share Posted February 10, 2013 Lower the front to match You can get stiffer springs, or spring spacers Or coilovers Thats what Im doing. I do want a stiffer rear & like 1.75-2 inch lower ride height too tho On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted February 10, 2013 Author Report Share Posted February 10, 2013 It's not that it's an unsafe drop.... But it's a good inch or so drop.... And I'm thinking if it drops that far like that imagine what it looks like when I wall it off........ I have had 4 people in my car plus the bass so its not as blown as some may have thought. But I deff need to look into some of that when I'm ready to wall her My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
bassfreake Posted February 10, 2013 Report Share Posted February 10, 2013 Mine is bad enough that when I've got my 20s on if it's just me and i hit a bump it scrapes and if i got anyone in the back seat then it scrapes the ties on the wheel well almost constantly... And I've only got 2 15lb subs and a sealed box and no amp right now... I'm looking into swapping out my springs Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. My Build Log Link to comment Share on other sites More sharing options...
Carbon Posted February 10, 2013 Report Share Posted February 10, 2013 Air lift or coilovers Link to comment Share on other sites More sharing options...
