DAmoreEngineering 26 minutes ago
If the head unit has SE outputs and the amplifier has SE inputs = coax cable
If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair
If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair
If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE
I don't put images in my signature to let people know I mean business.
Quick suggestion:
How about making a sticky thread so people can add what amp or head unit has SE outputs or Diff outputs? Then people could know what kind of rca to buy before they get their amp.
Edited by iwannabeloud
  • Like (+1 Rep) 4
great video!
FYI: http://www.wccaraudio.com if you need high quality RCA's ....just wanted to share that info :D
$50 to $60 for 3 feet. No thanks, I'll keep using what has been working just fine.
As much as your post contributes, ill post one that is just as lacking.
Then dont buy em.... And head back to radio shack........
Me,.. im ordering on Friday.
Edited by KyLar96
great video!
cool story bro :stfu2:
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
more good information...this is why the forum works so well!
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Awesome vid Tony! :good:
I just received my custom 20' SMD COAX cables and love them.
I haven't had a chance to install them yet, but I do have some very detailed measurements comparing them to the regular RG6 coax that I was using.
Resistance-wise the SMD COAX cables are better then RG6 which is impressive since RG6 has a very thick center conductor.
RG6 has less capacitance (better) then the SMD's, most likely due to the increased diameter it has. This is a very minimal difference though and the MUCH better flexibility of the SMD cable far outweighs the RG6 in my opinion.
The RG6 had about twice the inductance of the SMD cables which adds up to more inductive reactance in the upper frequencies.
All measurements were swept from 20Hz to 20kHz.
I've used two different types of RG6 COAX before and to me, these SMD COAX cables are much better.
They are MUCH more flexible and very well made.
I'll post more details after I install mine and do some more measurements.
For anybody interested or new to these cables:
Make sure you also check your HU for its output as well.
To make the best use of each cable type, you'd want to match the HU output to the amplifier input along with the correct cable type.
awesome! Glad you like them so far :)
Follow my Tweet (Twitter)
Site: http://www.wccaraudio.com
coupon code: SMDRCA15
15% off.
I do have matching Y adapters now too but i they aren't up on the site yet.
  • Who's Online   0 Members, 0 Anonymous, 4316 Guests (See full list)
